How safe is RegCure Pro?
2013-03-13T14:49:26+00:00
Should I allow RegCure PRO from Pareto Logic make changes on my pc?
2013-03-14T00:35:23+00:00
No! You should dump it immediately. Don't run it and don't let it do
anything.
Registry cleaning programs are all snake oil. Cleaning of the
registry isn't needed and is dangerous. Leave the registry alone and
don't use any registry cleaner. Despite what many people think, and
what vendors of registry cleaning software try to convince you of,
having unused registry entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
2013-03-13T17:28:09+00:00
As with all these 'SpeedUpMyPc' type of programs as safe as holding a rattle snake by its tail
120 additional answers
    2014-11-10T17:19:09+00:00
    I have Norton to protect my PC. Recently Norton has blocked all webb-sites related to paretologic
    because they are not save. Norton also blocked RegCure Pro  on the computer as it is not save according to Norton. I asked Norton to get i back! Now I have read what people has stated regarding Regcure Pro. For me it worked fine, I had no problems with it yet, but now i wonder.
    Shall I try to get ridd of it. Can ask Norton support to deleate it to be sure that everything rearly disappear!
    2014-11-10T23:35:14+00:00
    A little more research -- I do NOT TRUST anything about this download or company!  Just my decision and opinion.
          Judy Stough
    2014-11-11T15:40:34+00:00
    Now I managed to open there website!
    Explained that Norton does not like their website nor their product as both are not save.
    Stated that I will not prolong their service, if they do not handle the problem, they have with Semantic (Norton product).
    BR Bengt Zdebel
