How safe is RegCure Pro?
2013-03-13T14:49:26+00:00
Should I allow RegCure PRO from Pareto Logic make changes on my pc?
2013-03-14T00:35:23+00:00
No! You should dump it immediately. Don't run it and don't let it do
anything.
Registry cleaning programs are all snake oil. Cleaning of the
registry isn't needed and is dangerous. Leave the registry alone and
don't use any registry cleaner. Despite what many people think, and
what vendors of registry cleaning software try to convince you of,
having unused registry entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
2013-03-13T17:28:09+00:00
As with all these 'SpeedUpMyPc' type of programs as safe as holding a rattle snake by its tail
120 additional answers
    2014-02-09T18:59:56+00:00
    I SIMPLY FOUND THAT THERE SCAN WAS NOT FIXING ANYTHING, REPEATED DISC ERRORS DID NOT SHOW UP USING COMMAND PROMPT DSK CHK, AND FILE CLEANUP DID NOT SHOW ON CCLEANER. ORIGINALLY I GOT IT TO FIX A PROBLEM THAT I ENTERED INTO GOOGLE AND IT CAME CAME BACK "THREE STEPS TO FIX YOUR PC"  NEEDLESS TO SAY IT DID NOT MAKE AN ONCE OF DIFFERENCE. IT IS NOT AFFILIATED IN ANY WAY WITH MICROSOFT.   GEORGE GIBSON
    2014-02-20T04:12:32+00:00
    If only I had checked with Microsoft Community first.  I purchased RegCure Pro yesterday and, after reading the Q&A herein, I am now scared to use it.  A $30-lesson learned.  I should have learned my lesson 6 months ago when I purchased eFix Pro.  That was a disaster as well.  From now on, I'm consulting Microsoft Community prior to purchasing any and all software.
    2014-02-20T05:07:34+00:00
    STAY WITH WIN PATROL THEY WILL ANSWER YOU ALSO
