How safe is RegCure Pro?
2013-03-13T14:49:26+00:00
Should I allow RegCure PRO from Pareto Logic make changes on my pc?
2013-03-14T00:35:23+00:00
No! You should dump it immediately. Don't run it and don't let it do
anything.
Registry cleaning programs are all snake oil. Cleaning of the
registry isn't needed and is dangerous. Leave the registry alone and
don't use any registry cleaner. Despite what many people think, and
what vendors of registry cleaning software try to convince you of,
having unused registry entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
2013-03-13T17:28:09+00:00
As with all these 'SpeedUpMyPc' type of programs as safe as holding a rattle snake by its tail
120 additional answers
    2013-12-30T01:03:06+00:00
    Well it seems my email finally appeared and all my old ones reloaded...however all unread and my own folders disappeared so I have to reorganise them.....
    2014-01-17T20:22:59+00:00
    Thank you for the too-late warning. I wish you could pop-up the warning like any other pop-up warning if you can't block the solicitation of Regcure. How do I get the money back I spent on this so-called free snake oil company? And what about a social media campaign to discredit Regcure and its use of Microft's name?
    2014-01-18T13:36:29+00:00
    There is no law against producing a registry cleaner and charging for it.
    The website(s) use the Microsoft Certified Partner logos which is NOT a recommendation. The software author has to apply for the certification which is, unfortunately, too easy to get and may not even relate to the software being advertised..
