photoshop, Illustrator, CS6 interface too small on surface pro
2013-07-05T02:48:51+00:00
Hello, I just purchased the Surface Pro from Best Buy. I bought it to use adobe products such as Photoshop, Illustrator, and such. The menu and icons are so small making it nearly impossible to navigate through the tools and menus.
Are there any options? I love the tablet but will be returning it in the next week if I can't find a solution.
Kip
**Post moved by the moderator to the appropriate forum category.**
Windows for home | Windows 11 | Display and graphics
2015-06-22T12:28:10+00:00
I experienced this same issue last year. I only found the solution for Photoshop:
Go to Edit -> Preferences -> Experimental Features -> Select "Scale UI 200%" AND "Enable touch gestures"
2013-07-18T09:09:43+00:00
That a problem with Photoshop itself... Its not respecting the scaling factor of Windows. The MacOS had the same problem too after Retina displays came out.
I'm afraid you cant do anything about it. You have to wait until Adobe addresses this problem.
42 additional answers
    2014-05-06T16:28:31+00:00
    Hello. I downloaded a font with super jagged edges and there's no simple way to correct this in Photoshop that is on my laptop. My laptop has XP and now b/c Adobe no longer supports XP I cannot download Illustrator onto my laptop so I'm forced to use my Surface Pro 2 to clean the text up. Has this issue ever been solved by Adobe? If not is there a Surface Pro 2 app I can download to clean up TT font?
    2014-06-15T21:46:00+00:00
    Maybe in a mean time while adobe, autodesk and other big guys addressing the issue with screen resolution, windows could come up with idea of a better magnifier. Not the one that chasing cursor like crazy, driving me nuts!!! but few magnifiers  that could lie still on the areas where magnification needed.
    2014-08-04T03:03:36+00:00
    For Photoshop only:
