I experienced this same issue last year. I only found the solution for Photoshop:
Go to Edit -> Preferences -> Experimental Features -> Select "Scale UI 200%" AND "Enable touch gestures"
Hello, I just purchased the Surface Pro from Best Buy. I bought it to use adobe products such as Photoshop, Illustrator, and such. The menu and icons are so small making it nearly impossible to navigate through the tools and menus.
Are there any options? I love the tablet but will be returning it in the next week if I can't find a solution.
Kip
**Post moved by the moderator to the appropriate forum category.**
That a problem with Photoshop itself... Its not respecting the scaling factor of Windows. The MacOS had the same problem too after Retina displays came out.
I'm afraid you cant do anything about it. You have to wait until Adobe addresses this problem.
Wouv, that sucks! Super depressing even! Thx for answers.
I have the same problem with photoshop and illustrator, the only fix right now is to lower the screen resolution to 1600 x 900 (or lower) so the tool icons and menus are a little bit bigger. I think adobe should start fixing these things because with the surface and the new portable cintiqs this will be a big problem for mobile users. Good luck.
What GB version of Pro did you get, and does it run smoothly on it? Thanks
