photoshop, Illustrator, CS6 interface too small on surface pro
2013-07-05T02:48:51+00:00
Hello, I just purchased the Surface Pro from Best Buy. I bought it to use adobe products such as Photoshop, Illustrator, and such. The menu and icons are so small making it nearly impossible to navigate through the tools and menus.
Are there any options? I love the tablet but will be returning it in the next week if I can't find a solution.
Kip
**Post moved by the moderator to the appropriate forum category.**
Windows for home | Windows 11 | Display and graphics
2015-06-22T12:28:10+00:00
I experienced this same issue last year. I only found the solution for Photoshop:
Go to Edit -> Preferences -> Experimental Features -> Select "Scale UI 200%" AND "Enable touch gestures"
2013-07-18T09:09:43+00:00
That a problem with Photoshop itself... Its not respecting the scaling factor of Windows. The MacOS had the same problem too after Retina displays came out.
I'm afraid you cant do anything about it. You have to wait until Adobe addresses this problem.
42 additional answers
    2017-08-26T09:10:04+00:00
    Work it !!!!
    FINALLY!!!
    I didn´t seen that you had written before.
    THANKS!
    2017-08-26T09:52:31+00:00
    No worries ,thanks
    2017-08-26T20:30:58+00:00
    stupid answer. you try being a designer and using the on screen magnifier in a design program...
