update problem KB2670838
2013-02-27T15:34:01+00:00
Installed this today, it caused my Poppeeper to be flagged with a -1000 error. Rolled computer back and problem cured. Have hidden update until i know what to do.
Windows for home | Other | Email and communications
2013-02-28T23:31:41+00:00
YMMV but...
...Microsoft is aware of an issue some customers are experiencing when installing KB2670838 on certain laptop systems with hybrid graphics. We are looking into the situation and are considering blocking the update for systems that could be affected. Customers who are experiencing issues on systems that already have installed the update should consider uninstalling KB2670838.
Source: http://answers.microsoft.com/en-us/windows/forum/windows\_7-windows\_update/after-installation-of-update-kb2670838-win-7-keeps/66be9f5a-2257-4c4a-9c9c-5dc6f0f55d37?page=4
In the near future (one assumes), Microsoft should begin offering home users (only!) no-charge support for IE10 install and uninstall issues. You also may be eligible for the support if an IE10-related issue causes your computer to crash or if IE10 does
 not let you browse all sites. For now, however, you're on your own so you're best bet is to hide IE10 (*and KB2670838 IMHO*) & stick with IE9 for the time being.
[*Last Revised - 27 March 2013, 21:44 UTC*]
109 additional answers
    2013-02-27T20:45:07+00:00
    I also have problems with this update.
    After installing KB2670838 update Aero stopped working. After rolling back, Aero works again.
    2013-02-27T21:55:24+00:00
    just to second this... or third it... installed KB2670838and aero transparency was lost.  even 3ds max wouldn't load because of it.
    removed the KB2670838 update and all worked again... i am now removing it from our WSUS update server to prevent issues with other systems.
    2013-02-27T22:00:43+00:00
    If you look at the other post in here about this update, lots are having different problems.
    This update is suppose to be a pre rec to ie10 but it does not say it anywhere on Microsofts page for this update.
    the problem is it is breaking ie9, firefox, google chrome, Micrsoft Office 2010 and a whole bunch of other programs.
    Remove this using program and features, reboot and everything goes back to normal.
    Microsoft if you are looking in here you need to issue a fix for this update.
    What is interesting I went to the ie10 website, downloaded and installed it on a test machine I run and it did not ask me for this update (I did not install it on this machine prior).  I actually do not see a difference between ie 9 and 10.  but i will not put ie10 on till micrososft gets all these bugs out on my non test machines.
    2013-02-27T22:06:48+00:00
    I also had a problem.  After installing this update Windows Live Mail display has a black background.  It makes Windows Live Mail unusable.  Rolling the update back corrects the problem.
