KB2670838 installation and igdpmd64.sys blue screen
2013-03-01T07:51:21+00:00
Helllo,
yesterday (2013-02-28) I installed the update KB2670838 as sugested by the notice.
Afterwards I have a blue screen when using IE9.
The problem came up just after the selection of some text in IE 9 ...
and every time i tried to do so...
I tried many times with diferent programs by selecting any text and the problem wasn't there...
I tried other browsers and selecting wasn't a problem...
The file pointed out in the blue screen as responsible for the crash was igdpmd64.sys
said to be related with the Intel graphics card.
After looking here and there in forums and advices i decided to look for recent updates
and i noticed the one of Yesterday on graphical matters.
I removed it and hellas... now it is working well.
For information and for advice because the update is said to be advisable to be installed.
=======  My system =======
Computer: HP pavilion g6 Notebook
System: Windows 7 SP1 Home Premium Korean
System type: 64bit
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Memory: 4.00GB
Graphics: Mobile Intel(R) HD Graphics
Graphic adaptor version: 8.810.4.5000
DirectX version: DirectX 10
Browser: IE 9
Is there someone with similar problem that mannaged to install this update?
Or is that a bug on the update package that will be corrected?
2013-03-01T13:06:38+00:00
Try removing KB2670838. It is currently causing many problems. http://windows.microsoft.com/en-US/windows7/Remove-an-update
To hide the update to prevent it reinstalling select Start, All Programs, Windows Update, Check for Updates. When the list of available updates appears right click on KB2670838 and select Hide.
41 additional answers
    2013-03-01T17:05:57+00:00
    Exactly the same problem on the HP Pavilion dv7 of a customer of mine.
    I also found different reports from the last hours in other forums.
    The KB2670838 definitely makes some changes that cause the igdpmd64.sys to produce a Blue Screen on these HP notebooks.
    I guess there will be hundreds and thousands of HP customers heading for their computer doctors right now.
    2013-03-01T21:31:34+00:00
    Similar problem occured today on  Sony Vaio VPCCB
    (Radeon HD 6630M installed)
    BSOD when starting Internet Explorer in igdpmd64.sys
    after removal of  update  KB2670838 , and hiding it from update list
    everything works OK.
    still wait for permanent solution
    2013-03-02T00:25:41+00:00
    Encountered the same bugcheck in igdpmd64.sys while using IE.  This also caused a 1/2 inch black bar on the right side of IE9.  The scroll bar would then render inside that, but would still respond to mouse clicks on the far right side of the window (in the black area).  Uninstalling KB2670838 seems to have solved both the bugcheck and the black bar problem.
    System Info
    HP Envy 14
    Win7 Home Premium SP1 x64 [6.1.7601.17514]
    Intel HD Graphics 3000 / Radeon HD 6630M
    i7 2630QM
    2013-03-02T02:19:28+00:00
    We are aware of the issue with this particular update on some computers.
    Please look ino the response provided by Wuzzle(2) on 2nd March for assistance-
    http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_update/aero-disabled-after-platform-update-for-windows-7/a0d9c199-4bd4-460e-b5ed-b2195abe896c?page=2
