KB2670838 installation and igdpmd64.sys blue screen
2013-03-01T07:51:21+00:00
Helllo,
yesterday (2013-02-28) I installed the update KB2670838 as sugested by the notice.
Afterwards I have a blue screen when using IE9.
The problem came up just after the selection of some text in IE 9 ...
and every time i tried to do so...
I tried many times with diferent programs by selecting any text and the problem wasn't there...
I tried other browsers and selecting wasn't a problem...
The file pointed out in the blue screen as responsible for the crash was igdpmd64.sys
said to be related with the Intel graphics card.
After looking here and there in forums and advices i decided to look for recent updates
and i noticed the one of Yesterday on graphical matters.
I removed it and hellas... now it is working well.
For information and for advice because the update is said to be advisable to be installed.
=======  My system =======
Computer: HP pavilion g6 Notebook
System: Windows 7 SP1 Home Premium Korean
System type: 64bit
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Memory: 4.00GB
Graphics: Mobile Intel(R) HD Graphics
Graphic adaptor version: 8.810.4.5000
DirectX version: DirectX 10
Browser: IE 9
Is there someone with similar problem that mannaged to install this update?
Or is that a bug on the update package that will be corrected?
2013-03-01T13:06:38+00:00
Try removing KB2670838. It is currently causing many problems. http://windows.microsoft.com/en-US/windows7/Remove-an-update
To hide the update to prevent it reinstalling select Start, All Programs, Windows Update, Check for Updates. When the list of available updates appears right click on KB2670838 and select Hide.
41 additional answers
    2013-03-01T12:20:07+00:00
    I have a similar problem with a HP Pavilion dv7 laptop
    2013-03-01T12:42:55+00:00
    Its an Recommended/Optional update and as such theres generally no reason to install it
    2013-03-01T14:29:15+00:00
    My wife had the same issue on her HP Pavillion DV6 laptop with Windows 7 Home Premium x64 (SP1) with 8GB RAM. The BSOD pointed to the igdpmd64.sys file which led me here. I removed the KB as recommended above and rebooted the box. I hid the update and the systems seems to be running fine now.
    Many thanks to all for the assist in correcting this. Happy Wife, Happy Life. :)
    2013-03-01T17:04:42+00:00
    Thank you...this seemed to resolve my issue!  That was really frustrating!
