FSX Acceleration Error Code 1-80004005
2012-07-17T17:37:21+00:00
Ok, I just installed Flight Simulator Acceleration and when ever i start FSX i get a error message saying: "sorry,an unexpected error occured which is prventing product activation from being completed ERROR CODE 1-80004005" i've searched bout 5 hours on the Internet trying to find a solution. The only thing i can find is that its something with the registry. Please Help!
Windows for home | Other | Gaming
2012-07-18T06:00:45+00:00
1.     Has the game ever worked earlier or it is the first time you are trying to play?
2.     Which operating system is installed on the computer?
Method 1:
You may try the steps from the following link and check if it works:
Flight Simulator X: “An error occurred while attempting to activate the product The problem may be due to an incomplete installation of the application”
http://support.microsoft.com/kb/960481
Method 2:
Registry Disclaimer: ****Important this section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows: ****http://support.microsoft.com/kb/322756
a. Click Start and type regedit in the search bar and pressenter.
b. Browse to the following location:
HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS{4D36E967-E325-11CE-BFC1-08002BE10318} ****c. Find Upperfilters listed under it, and check its value, if its 0 change it to PartMgr and click OK out.
Let us know if it helps!
84 additional answers
    2018-01-10T22:01:03+00:00
    Your sure right about the ringer part!!!! I have a question for you😁You know anything about FSX STEAM version? Does it install over FSX & Acceleration pack or is it standalone? Is it wortb it?
    I don't know anything about FSX STEAM VER., all I'm trying to do is to register the FSX ACCELERATION The second part of your question, again I'm behind the 8 ball Don't know, sorry...
    2018-01-10T22:23:44+00:00
    Hi Len
    Sorry. No. I´m in the same situation as you.
    Henning
    2018-01-10T22:27:03+00:00
    Very important:
    PartMgr is Case Sensitive!!!
    Yes I know, but it did not helped me.
    Henning
    2018-01-10T22:33:55+00:00
    Microsoft FSX is a bad joke, full of tricks and jokes.
    You know what a bad joke is don't you?
    Steam FSX is just FSX Acceleration tarted up.
    I put FSX in the trash can years ago along with all of this Micro(scopic)Soft(ee) garbage.
    It is just kid's stuff.
    Try spending $199 instead on Lockheed Martin's Prepare3D written in 64-bit for Windows 10 64-bit operating systems.
    No point in struggling with out of date 32-bit systems.
    Ever fancied a - bit - of something to - byte -?
    Micro and Soft is the size of Bill Gate's 'appendage'.
    Remember Mrs Bobbit?  \Ö/
    Hi Ian
    Thank you for your poetry/adwise, but I have grandchildren who likes to fly on the PC. I have offered 150$ years ago
    for the two CDs. So dam BG and his small balls.
