FSX Acceleration Error Code 1-80004005
2012-07-17T17:37:21+00:00
Ok, I just installed Flight Simulator Acceleration and when ever i start FSX i get a error message saying: "sorry,an unexpected error occured which is prventing product activation from being completed ERROR CODE 1-80004005" i've searched bout 5 hours on the Internet trying to find a solution. The only thing i can find is that its something with the registry. Please Help!
Windows for home | Other | Gaming
2012-07-18T06:00:45+00:00
1.     Has the game ever worked earlier or it is the first time you are trying to play?
2.     Which operating system is installed on the computer?
Method 1:
You may try the steps from the following link and check if it works:
Flight Simulator X: “An error occurred while attempting to activate the product The problem may be due to an incomplete installation of the application”
http://support.microsoft.com/kb/960481
Method 2:
Registry Disclaimer: ****Important this section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows: ****http://support.microsoft.com/kb/322756
a. Click Start and type regedit in the search bar and pressenter.
b. Browse to the following location:
HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS{4D36E967-E325-11CE-BFC1-08002BE10318} ****c. Find Upperfilters listed under it, and check its value, if its 0 change it to PartMgr and click OK out.
Let us know if it helps!
84 additional answers
    2018-01-09T10:57:18+00:00
    I have window 10 64
    2018-01-09T11:12:49+00:00
    I may have to look into FSX Steam Edition, I spent a lot of money as far ...
    2018-01-09T11:20:07+00:00
    Budley...................... Right on !!!!! I had partmgr as you said and just edited it to PartMgr and that did the trick.......
    Changing the case solved my issue as well. The partmgr was already there, I set the case to PartMgr, started FSX and it come up with the activation window for my key. Thanks for the fix.
    should not have to go thro the ringer for a game FSX
    2018-01-09T11:43:10+00:00
    I need to activate My FSX acceleration expansion pack
    Depends on where you reside.
    Try this link for the correct FSX activation telephone number.
    https://www.microsoft.com/en-us/licensing/existing-customer/activation-centers.aspx
    Personally I have given up with FSX and use Steam FSX without all of the activation hassle.
    It also has a very useful tool with the ability to fully verify the installation and easily repair it if needs be.
    If you do install Steam FSX you - MUST - run this verification tool - BEFORE - attempting to use the program.
    If your rig is up to it you should better spend $199 on Lockheed Martin's Prepare3D v4.1 launched in 2017.
    Check it out before you go any further as it is compiled on 64-bit architecture which is far more suitable for your 64-bit OS.
    Lockheed Martin, AKA Prepar3D, recommends Windows 10 and so do I as I can run Steam FSX at 40 frames per second.
    Get back to me if you need any further assistance.
    I have been using FSX, etc. for eight years.
