FSX Acceleration Error Code 1-80004005
2012-07-17T17:37:21+00:00
Ok, I just installed Flight Simulator Acceleration and when ever i start FSX i get a error message saying: "sorry,an unexpected error occured which is prventing product activation from being completed ERROR CODE 1-80004005" i've searched bout 5 hours on the Internet trying to find a solution. The only thing i can find is that its something with the registry. Please Help!
Windows for home | Other | Gaming
2012-07-18T06:00:45+00:00
1.     Has the game ever worked earlier or it is the first time you are trying to play?
2.     Which operating system is installed on the computer?
Method 1:
You may try the steps from the following link and check if it works:
Flight Simulator X: “An error occurred while attempting to activate the product The problem may be due to an incomplete installation of the application”
http://support.microsoft.com/kb/960481
Method 2:
Registry Disclaimer: ****Important this section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows: ****http://support.microsoft.com/kb/322756
a. Click Start and type regedit in the search bar and pressenter.
b. Browse to the following location:
HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS{4D36E967-E325-11CE-BFC1-08002BE10318} ****c. Find Upperfilters listed under it, and check its value, if its 0 change it to PartMgr and click OK out.
Let us know if it helps!
84 additional answers
    2017-12-09T11:52:31+00:00
    Method 1:
    Method 2:
    The above solution is correct - the value of Upperfilters may already be "partmgr", if it is, it has to bechanged to uppercase P and M "PartMgr" then it works like a charm.
    2017-12-09T12:20:21+00:00
    verget it I pot it right out of the window after 3month madnes  so I bought me a different computer .
    thanks to every one
    2017-12-09T15:36:35+00:00
    thanks to every one
    Yeah.... Me too
    Legitimate copy of FSX. WILL NOT WORK on Microsoft computer. It IS registered and activated..... So I have wasted my money.
    Completely and utterly **** with Microsoft. Just couldn't care less unless you are a corporate client.
    Just got more to do with my life than talk to complete morons on their so called helplines. Passed through 5 different advisors all of whom claimed to be from Microsoft Support, and offered solutions like the above, but eventually said they would have to put me through to somebody who deals with Game support......because they didn't deal with games........  Aaaaaaaaggggggghhhhhhh.
    Mr Gates....... You need to get back in there and ****.
    Microsoft have screwed my flight simulator. Not happy. Not happy at all.
    Thanks guys, but not wasting one more minute on it.
    2017-12-09T18:03:55+00:00
    I had the same problem! Eventually, I gave up and bought the FSX Steam Edition. It is cheap and works much better. Frustrating but Microsoft Support is useless.
