Yeah.
Go look in C:\Windows\System32\drivers
Right click on athurx.sys and choose Properties. Look at modified date on Details tab. It should be from May 2011.
like the title I get a BSOD when running defrag. When i analyzed my disk it said that it was 4% fragmented so i ran the defrag and up popped my BSOD. I am switching to a ne HDD tomorow so i can see if that stops these BSODs from happening, but for now i am wondering what is causing the BSOD.
Yeah.
It says it was modified on may 20 2010 2:00 am
Since you're not able to update normally, do like this:
Right click on the driver .sys you downloaded from my link at Drivers\Win7\x64\
Choose copy.
Go to C:\Windows\System32\drivers
Right click in blank white space and choose paste. Choose replace or similar when it asks.
Reboot.
(Sorry, should be June 2011, not May.) :)
Ok i Got it and now the date is 6/18/11. i believe it is now, for real, fixed. thanks again
