I get a Blue Screen when running defrag
2012-06-07T09:21:27+00:00
like the title I get a BSOD when running defrag. When i analyzed my disk it said that it was 4% fragmented so i ran the defrag and up popped my BSOD. I am switching to a ne HDD tomorow so i can see if that stops these BSODs from happening, but for now i am wondering what is causing the BSOD.
    2012-06-07T20:04:13+00:00
    Same issue still:
    1: kd> lmvm athurx
    start             end                 module name
    fffff88002612000 fffff880027ec000   athurx   T (no symbols)
        Loaded symbol image file: athurx.sys
        Image path: \SystemRoot\system32\DRIVERS\athurx.sys
        Image name: athurx.sys
        Timestamp:        Thu May 20 07:48:34 2010 (4BF52192)
        CheckSum:         001E3610
        ImageSize:        001DA000
        Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Best advice is to follow what I've said about installing using the device manager, as that has not been done well yet.
    "Download. Extract. Open device manager. Right click on wireless. Update driver software. Browse my computer. Let me pick. Have disk. Browse.
    Navigate to extracted folder and double click the .inf. Click ok then next and it will install."
    http://www.atheros.cz/atheros-wireless-download.php?chipset=64&system=6
    2012-06-07T20:12:58+00:00
    Yes i tried that before but there are 2 .inf files so i dont know which one to intsall?
    2012-06-07T20:14:48+00:00
    No, I have it on my drive right now at the moment. There is only one .inf file - the correct one.
    Drivers\Win7\x64\netathurx.inf
    2012-06-07T20:19:00+00:00
    ok I will try redownloading it
    2012-06-07T20:23:20+00:00
    Ok i installed it and my PC is running well. Like before i will come back to you if i need help again. thanks for the help and support that you are lending! :)
    just to make sure, the file i install is the athurx.inf correct?
