I get a Blue Screen when running defrag
2012-06-07T09:21:27+00:00
like the title I get a BSOD when running defrag. When i analyzed my disk it said that it was 4% fragmented so i ran the defrag and up popped my BSOD. I am switching to a ne HDD tomorow so i can see if that stops these BSODs from happening, but for now i am wondering what is causing the BSOD.
    2012-06-13T04:16:07+00:00
    2012-06-13T04:24:39+00:00
    Go into the bios settings and set it to Optimzed Defaults then save.
    After, disable the onboard video adapter, set the primary display to be PCI-e.
    Save again.
    Boot to Windows and install this for your new AMD video card (congrats by the way) if it is 5000 series or higher:
    http://downloads.guru3d.com/AMD-Catalyst-12.x-(8.980.0-June-4)-Unofficial-BETA-download-2923.html
    Install the latest Realtek HD Audio Codec driver from the right side of their main page to update this:
    RTKVHD64 RTKVHD64.sys Tue Nov 30 04:03:19 2010 (4CF4BDD7)
    Uninstall Acronis True Image:
    snapman  snapman.sys  Fri Oct 06 09:43:53 2006 (45265D99)
    Unfortunately though, I still see these files, although they are unloaded:
    jswpslwfx.sys
    scmndisp.sys
    Delete them if you find them. Should be at C:\Windows\System32\drivers
    2012-06-13T04:39:54+00:00
    Also, if the motherboard has wireless built in AND you are using another adapter as an add-on - then disable the wireless in the bios too.
    2012-06-13T04:49:08+00:00
    Ok I have installed the files and am in process of rebooting. and ya i got the radeon hd 7770 and im super excited!!! anyway should i try to delete the jswp... and the scmn.... files?
    2012-06-13T04:50:02+00:00
    and the motherboard doesnt have wireless so that isnt a problem
