I get a Blue Screen when running defrag
2012-06-07T09:21:27+00:00
like the title I get a BSOD when running defrag. When i analyzed my disk it said that it was 4% fragmented so i ran the defrag and up popped my BSOD. I am switching to a ne HDD tomorow so i can see if that stops these BSODs from happening, but for now i am wondering what is causing the BSOD.
  1. Deleted
    2012-06-07T06:41:14+00:00
    Running Windows 7 64-bit OS. After about 30-60 minutes of running my computer gives me a BSOD. This is what it says:
    A problem has been detected and windows has been shut down to prevent damage to your computer.
    If this is the first time you have seen this stop error screen, restart your computer. If this screen appears again follow these steps:
    Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
    Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select safe mode.
    Technical Information:
    *** STOP:   0x0000007E (0xFFFFFFFFC0000005, 0xFFFFF88000E5E156, 0xFFFFF88003D6A1E8, 0xFFFFF88003D69A40)
    ***   wdf.01000.sys - Address FFFFF88000E5E156 base at FFFFF88000E29000, DateStamp 4a5bc19f
    Collecting crash data for crash dump …
    Initializing disk for crash dump …
    Beginning dump of physical memory.
    Dumping physical memory to disk: 100
    This has happened 7 or 8 times on the computer i am building. I got a new power supply because i thought that was the problem and now i have 600 watts (up from 200 that i borrowed from an old dell). This did not seem to fix the problem. I believe i have the latest BIOS as well
    My computer parts are:
    ASRock z68 Pro3 MOBO
    Intel core-i5 2500 CPU (not the unlocked model) with stock heatsink
    8 gigabytes of HyperX RAM DDR3 PC3 1333
    Seagate barracuda 80 gigabyte HDD (also from old dell)
    Diablotek DA series 600 watt PSU
    Integrated graphics intel 3000 in MOBO and CPU (Until i get a GPU)
    No sound drivers
    AOC 21 inch monitor
    Thanks for any help or advice, I really want to start gaming and working on this PC again.
    2012-06-07T06:43:02+00:00
    Please copy files from C:\Windows\Minidump folder to desktop. Upload the latest 3 or so to Sky Drive then paste a link here.
    We'll fix it all up for ya.
    2012-06-07T06:44:55+00:00
