System Restore is no longer available.
2011-12-31T15:21:55+00:00
When I go to "Start" / System Restore, dialog box appears " System Restore is no longer protecting your computer. Restart and try again." I have done that several and restarted, with always the same result. How can I enable SR again?
TIA
2012-01-05T08:12:06+00:00
That was the only thing i have in my notes about the SR service and that error and I did recreate it one more time here to be sure my notes made sense.  I have that same error for other Services and it is usually a missing file, so usually easy to fix
Do you know if SR has worked properly since Avast has been installed?
Since your SR Service is broken, and if that is the only problem you know about, you could:
1.  Export the SR Service section of your registry and send it here for analysis
2.  I can export the SR Service part of my registry and send it to you for installation on your system.   I have instructions for that (the SR Service is not very exciting to look at)
3.  You can totally reinstall System Restore (you don't have to reinstall XP - just the SR part)
a.  I have instructions for that and you do not need an XP installation CD
b.  If you reinstall SR, you will lose all your current Restore Points
c.  If SR doesn't work anyway, who cares about number b
Even though Avast is pretty good, I wish you would do this while you are thinking about it:
Download, install, update and do at least one full scan with these free malware detection programs:
Malwarebytes (MBAM):  http://malwarebytes.org/
SUPERAntiSpyware: (SAS):  http://www.superantispyware.com/
They can be uninstalled later if desired.
46 additional answers
    2012-01-23T07:43:32+00:00
    Hi Gerry
    Here's the data you requested:
    Volume (C:)
        Volume size                                = 74.52 GB
        Cluster size                               = 4 KB
        Used space                                 = 14.71 GB
        Free space                                 = 59.81 GB
        Percent free space                         = 80 %
    Volume fragmentation
        Total fragmentation                        = 0 %
        File fragmentation                         = 0 %
        Free space fragmentation                   = 0 %
    File fragmentation
        Total files                                = 37,403
        Average file size                          = 821 KB
        Total fragmented files                     = 22
        Total excess fragments                     = 81
        Average fragments per file                 = 1.00
    Pagefile fragmentation
        Pagefile size                              = 1.31 GB
        Total fragments                            = 1
    Folder fragmentation
        Total folders                              = 3,622
        Fragmented folders                         = 1
        Excess folder fragments                    = 1
    Master File Table (MFT) fragmentation
        Total MFT size                             = 70 MB
        MFT record count                           = 41,286
        Percent MFT in use                         = 57 %
        Total MFT fragments                        = 4
    Fragments       File Size       Most fragmented files
    15              865 KB          \Documents and Settings\Ben Stevenson\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\places.sqlite-wal
    11              576 KB          \Documents and Settings\Ben Stevenson\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\cookies.sqlite-wal
    8               3 MB            \Documents and Settings\All Users\Application Data\AVAST Software\Avast\log\Setup.log
    7               2 MB            \Program Files\AVAST Software\Avast\Setup\setup.log
    6               739 KB          \Documents and Settings\All Users\Application Data\Lavasoft\Ad-Aware\Logs\Debug.log
    6               506 KB          \Documents and Settings\Ben Stevenson\Local Settings\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\Cache\_CACHE_003_
    6               312 KB          \Documents and Settings\Ben Stevenson\Local Settings\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\Cache\_CACHE_002_
    5               64 KB           \WINXP\system32\wbem\Logs\wbemess.lo_
    5               2 MB            \WINXP\WindowsUpdate.log
    4               36 KB           \Documents and Settings\All Users\Application Data\AVAST Software\Avast\log\aswAr.log
    3               1 KB            \Documents and Settings\Ben Stevenson\ntuser.dat.LOG
    3               17 KB           \Documents and Settings\Ben Stevenson\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\prefs.js
    3               1 MB            \Documents and Settings\Ben Stevenson\Local Settings\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\urlclassifier.pset
    2               466 KB          \Documents and Settings\All Users\Application Data\AVAST Software\Avast\log\usntr.log
    2               56 KB           \System Volume Information\_restore{D9BF005F-E46E-46BB-8434-E287FC33F533}\RP20
    2               193 KB          \Documents and Settings\Ben Stevenson\Local Settings\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\Cache\_CACHE_001_
    2               219 KB          \Documents and Settings\All Users\Application Data\Lavasoft\Ad-Aware\statistics.dat
    2               26 KB           \Documents and Settings\All Users\Application Data\Lavasoft\Ad-Aware\Backup\userinit.exe.2b3cdd029c7ff9b1297239dfd873b726.a93aee1928a9d7ce3e16d24ec7380f89.aawbackup
    2               7 KB            \Documents and Settings\Ben Stevenson\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\localstore.rdf
    2               8 KB            \Documents and Settings\Ben Stevenson\Local Settings\Application Data\Mozilla\Firefox\Profiles\3z25hbx1.default\Cache\_CACHE_MAP_
    2               1 MB            \WINXP\system32\CatRoot2\tmp.edb
    2               5 KB            \WINXP\system32\wbem\Logs\wbemess.log
    More next.
    2012-01-23T07:57:23+00:00
    Hi Gerry
    Here's the Commit Charge:
    Total                      387500
    Limit                    2220072
    Peak                      418696
    Regarding the auturuns that I had asked. If I uncheck an item does it mean that it will never come on again, or that it will simply not load on startup and will come on when the system requires it.
    2012-01-23T08:35:57+00:00
    Hi Daavee
    Thanks for your response.
    My internet connection is cable.
    Fromhttp://www.speedtest.net/:
    Ping      28 ms
    Download speed    2.27 Mbps
    Upload speed          0.24  Mbps.   Is this one important?  I don't upload anything as I don't have a website or Facebook or Twitter.
    And for  http://www.speakeasy.net/speedtest/   there are just 8 US cities to choose from, and I'm not in the US. Can it be done?
    Antivirus is free Avast which I update and do every weekend.
    I have both of those antiSpyware which I update and do every weekend.
    In Task Manager :
    1. Physical Memory - Total            96560
    2. Commit Charge - Total             471084
    3. Commit Charge - Limit           2220072
    4. Commit Charge - Peak            473464
    Pls tell me what do these items mean.
    Pls also help me on a problem for which I have not got any answer in this thread:
    My monitor screen is put to go off every 15 mins. But it doesn't go off at all nowadays. Adjusted it to 10 mins but it still remains on all the time. The video streaming is affected when the screen is off, which should not be the case, so I need this problem fixed so I can test the video streaming problem. Now that the screen is never off, I don't have the streaming problem.
    2012-01-23T13:58:16+00:00
    Long rants off topic create long threads!
