"IOLORGDF32 Program not found skip autocheck" after upgrade win7 to win8
2012-11-11T05:36:19+00:00
How to solve the "IOLORGDF32 Program not found skip autocheck" after upgrade win7 to win8
2012-11-20T15:53:12+00:00
1 - Press the ‘Windows + R’ key on the keyboard.
2 - Write 'regedit' and press ENTER.
3 - Click with right button on HKEY_CLASSES_ROOT.
4 - Click on Find.
5 - Write iolorgdf32and press ENTER.
6 - On Right side will show the iolorgdf32, with some messages, like chdisk, chkmessage etc.
7 - Delete this register.
9 - Reset your computer.
62 additional answers
    2013-08-19T17:25:12+00:00
    Ha funcionado a la perfeccion, Gracia
    1 - Presionar el  "Windows + R  en el teclado.
    2 - Escriba " regedit " y presione ENTER.
    3 - Haga clic con el botón derecho en HKEY_CLASSES_ROOT.
    4 - Haga clic en Buscar.
    5 - Escribe  iolorgdf32 y pulse  ENTER.
    6 - En el lado derecho, el  iolorgdf32, con algunos mensajes, como chdisk, etc chkmessage
    7 - Eliminar este registro.
    9 - Reiniciar el ordenador.
    No sirve pues no aparece archivo iolorgdf32 al Buscar en HKEY_CLASSES_ROOT
    2013-09-05T13:17:28+00:00
    How to solve the "IOLORGDF32 Program not found skip autocheck" IN win8
    2013-09-24T16:23:16+00:00
    Hi,my name is Gaurav and i had same problem but i manage to solve it by doing some steps.
    If you have application like Vaio care then just  click on the option system tune upand rest will done itself by the software when you start your laptop next time.
    2013-09-25T15:47:29+00:00
    Thank you for sharing for the information.
    Glad to know that your issue is resolved. In case, if you need any assistance you may always post your questions along with your valuable suggestions in this forum.
    It's about the problem with "iolorgdf32 etc." Working in Windows 8 I suddenly got this message whilst starting up. I tried your solution, but I didn't get "showing on right side the iolorgdf32 with messages like chdisk etc. There was a delete button neither.
    Do you have an explanation? Is there a alternative solution?
    Thank you so much.
    Kindest regards,
    Rob Vanderwildt, Antwerp, Belgium
