assuming location is;
hkey_local_machine -- system -- controlset001 -- control -- session manager.
what is the exact file that needs to be deleted, i do not have iolorgdf32. as a file name.
the only mention of iolorgdf32 is at above location and is named BootExecute and at data displays autocheck autochk * autocheck iolorgdf32 c:\users\richard\appdata\roaming\iolo\
Hi, I had the same problem.
iolorgdf is used for the "registry defragmentation"
If you search "iolorgdf" on your drive C, you will find a program named "iolorgdf64.exe" (c:\windows\system32). As my windows 8 is a 64 bits release (is there a 32 bits release ?), I change
autocheck autochk * autocheck iolorgdf32 c:\users<YourUser>\appdata\roaming\iolo\
by
autocheck autochk * autocheck iolorgdf64 c:\users<YouUser>\appdata\roaming\iolo\
It works perfectly.
<YourUser> is your login user on W8, as richard in the example given by RichardFizia
In that case, don't remove any information from your registrySorry in my English is not fluent as I want. I hope i've understood me !
hi,
i just changed that path
to
that
autocheck autochk * autocheck iolorgdf64 c:\users\richard\appdata\roaming\iolo\
that problem is fixed but now unable to update my window while am having purchased window
