"IOLORGDF32 Program not found skip autocheck" after upgrade win7 to win8
2012-11-11T05:36:19+00:00
How to solve the "IOLORGDF32 Program not found skip autocheck" after upgrade win7 to win8
2012-11-20T15:53:12+00:00
1 - Press the ‘Windows + R’ key on the keyboard.
2 - Write 'regedit' and press ENTER.
3 - Click with right button on HKEY_CLASSES_ROOT.
4 - Click on Find.
5 - Write iolorgdf32and press ENTER.
6 - On Right side will show the iolorgdf32, with some messages, like chdisk, chkmessage etc.
7 - Delete this register.
9 - Reset your computer.
62 additional answers
    2013-11-26T21:03:12+00:00
    I STILL DONT HAVE AN ANSWER TO MY PROBLEM : iolorgdf32   autocheck    what do I do?  Do I have to download it   -   not in my registry   -     ???????
    ******@videotron.ca
    Claudine Vaillancourt
    Levis, QC, Canada
    G6V9M5
    2013-11-30T15:48:00+00:00
    You know you said to delete the register. Do you mean by highlighting all items that appear on the right panel and click delete?
    It comes up with a message sayin my laptop may not function properly after deleting such items
    2013-12-08T12:42:48+00:00
    4 - Click on Find.
    valeu, resolveu o problema, obrigado.
    2013-12-10T21:21:40+00:00
    Hiya,
    I have the same problem, as I cant find this iolorgd32 in any of the places suggested.
    My computer is also Sony Vaio and I have Windows is 8.1 Since I installed this Windows my performance is very poor, the system crashes all the time.
    I have this computer for less then a year and my old one (8years now) works better then this one.
    Can someone please advise me?
    All the best,
    Diana Gheorghiu
