what is runtime broker, and why does it use so much memory?
2012-10-28T14:43:19+00:00
in task manager there is process called Runtime Broker. and it uses over 600 MB of my ram. putting my average usage at 60% on my 4 gig laptop. not noticed any performance issues yet. just a lot memory being used. makes me think of windows vista almost bc it had same issue in past. it would use all system resources.
    2012-10-31T11:51:26+00:00
    I just got off a long chat session with an Answer tech rep, or whatever they are called. He did actually take the time to listen to me and I used the MS Diagnostic tool to collect logs and upload it to them. He said that he will "endorse the case and pass it to his team lead so they can gather as much evidence from other users as possible". It took me a long time to actually get through to a live chat support rep but if everybody else who is experiencing this problem could do the same then we might get somewhere.
    Listen to me - I'll be organising sponsored walks next! :)
    2012-10-31T11:54:46+00:00
    Hi - it would be handy if you could tell us what apps you uninstalled. I would keep an eye on the process though as I thought I had it cracked at one point and then it started collecting memory like it was going out of fashion again.
    I have only installed a few apps as far as I can remember, maybe only two - a time tile and youtube + is all I can remember. I did have to try about 5 or 6 different time tiles before I found one that actually worked without having to open it but I uninstalled all the useless ones.
    2012-10-31T13:27:32+00:00
    :D Great to know that you have got through to someone who has payed attention. The tech rep I got in touch with was useless.
    2012-10-31T15:07:42+00:00
    the apps I installed were:
    Bank of America
    Tunein Radio
    Netflix
    The Time (this might be the same clock program you had)..
    The Wall Street Journal
    Fresh Paint
    HowStuffWorks
    StumbleUpon
    The Big Picture
    Windows 8 Cheat Keys
    Periodic Table
    USA Today
    Wikipedia
    Wordament
    I'll be checking which one of these is the culprit.  The ones that came with Win8 software seem to be running fine.  If you see anything common with what you had/have please let me know so I can narrow it down much quicker.
    2012-10-31T17:55:27+00:00
    The only two we have in common are Wikipedia and The Time.
    To make sure we are talking about the same time app you can check the details in the app store program - mine was developed by Jeff Key (it's a green tile).
    Outside of metro apps I installed Stardock's Start8 button but I stopped that program for an hour or so and it did not seem to make any difference to the behaviour of Runtime Broker so I am ruling that out as a potential troublemaker for now.
    I'm going to uninstall the two apps we have in common (one at a time) and see if it has any effect at all but I am not overly optimistic.
