Wifi Toggle switch is greyed out
2012-11-04T04:04:43+00:00
Original Title: How to turn on WiFi Capability on Windows 8
I upgraded my Laptop Toshiba L500D from Windows 7 Home Premium (x64) to Windows 8 Pro (x64) a few days ago, then I realized yesterday I could not connect to WiFi connection. I have tried search on the internet how to fix it, but no luck. Here are the following list I have tried so far:
  1. Update to latest Driver by going to "Device Manager", click right "Realtek RTL8187SE Wireless LAN PCIE Network Adapter" then click "Update Driver Software...".
  2. Go to Toshiba Website, download "Realtek Wireless Lan Driver" for Windows 7 (x64) and install it by running in Windows 7 compatibility mode.
  3. Go to BIOS, by pressing F2 before Windows 8 loaded, and enable Wireless Communication.
  4. Troubleshooting "Network Adapter (WiFi)" and it gave this advice:
           "Turn on wireless capability
Use the switch on the front or side of the computer,            or function keys if available,            to enable wireless capability on this computer."
  1. Go to Settings -> Change PC Settings -> Wireless, and I got this:
http://img694.imageshack.us/img694/2959/62721723.png
How am I suppose to switch it on, if the switch is disabled? The airplane is also off, so I suppose the Wireless switch should be enable so I can turn it on and off, but no, the wifi switch is still disabled.
Any advice will be appreciated.
Cheers,
simply.puzzle
2012-11-29T21:38:42+00:00
I had a similar issue.. I used the diagnostics to resolve the issue... here are the steps I took.
  1. Right Click network icon in taskbar and select "open network and sharing center"
  2. highlight wifi connection then at top click "diagnose this connection"
the troubleshooter will discover that the WiFi connection is turned off and offer a "apply fix" option click that and windows will enable the wifi connection...
I had the same issues as the OP and Geecat where the Fn switch just didn't work, so I worked through it as outlined above... Looks like with Win 8 the troubleshooter is even more necessary... Not sure how I feel about that, but it is what it is.
105 additional answers
    2016-10-12T08:40:22+00:00
    Hi guys, i know dis maybe kind of late but i had a similar issue lately and apparently after all the troubleshooting from updating drivers to uninstalling and reinstalling them but jus right before i thought of reinstalling windows 8. I decided to swap keyboards with my other compaq machine and it seems my laptop had a defective keyboard so the F12 key to toggle between switching on and off the wireless capability wasnt working, along with other keys. so maybe if anyone else comes across the same issue, its an avenue worth visiting.
    2017-02-05T18:26:42+00:00
    I also got this problem three day ago. I done every thing which is possible but could'nt find solution.
    Today i am checking my apps. I saw an app "wireless display adapter" which is automatically installed. i just uninstall it and my wifi worked again.
    You must have to try this.
    Sorry for my poor english
    Cheeer...
    2017-02-06T03:57:08+00:00
    You are probably 1 in 1000 million that fixed your unusual problem
    2017-02-06T03:59:44+00:00
    The problem is Win 10 not any drivers or F buttons! I uninstalled Win 10 and The HP dv7t worked flawless
