Wifi Toggle switch is greyed out
2012-11-04T04:04:43+00:00
Original Title: How to turn on WiFi Capability on Windows 8
I upgraded my Laptop Toshiba L500D from Windows 7 Home Premium (x64) to Windows 8 Pro (x64) a few days ago, then I realized yesterday I could not connect to WiFi connection. I have tried search on the internet how to fix it, but no luck. Here are the following list I have tried so far:
  1. Update to latest Driver by going to "Device Manager", click right "Realtek RTL8187SE Wireless LAN PCIE Network Adapter" then click "Update Driver Software...".
  2. Go to Toshiba Website, download "Realtek Wireless Lan Driver" for Windows 7 (x64) and install it by running in Windows 7 compatibility mode.
  3. Go to BIOS, by pressing F2 before Windows 8 loaded, and enable Wireless Communication.
  4. Troubleshooting "Network Adapter (WiFi)" and it gave this advice:
           "Turn on wireless capability
Use the switch on the front or side of the computer,            or function keys if available,            to enable wireless capability on this computer."
  1. Go to Settings -> Change PC Settings -> Wireless, and I got this:
http://img694.imageshack.us/img694/2959/62721723.png
How am I suppose to switch it on, if the switch is disabled? The airplane is also off, so I suppose the Wireless switch should be enable so I can turn it on and off, but no, the wifi switch is still disabled.
Any advice will be appreciated.
Cheers,
simply.puzzle
2012-11-29T21:38:42+00:00
I had a similar issue.. I used the diagnostics to resolve the issue... here are the steps I took.
  1. Right Click network icon in taskbar and select "open network and sharing center"
  2. highlight wifi connection then at top click "diagnose this connection"
the troubleshooter will discover that the WiFi connection is turned off and offer a "apply fix" option click that and windows will enable the wifi connection...
I had the same issues as the OP and Geecat where the Fn switch just didn't work, so I worked through it as outlined above... Looks like with Win 8 the troubleshooter is even more necessary... Not sure how I feel about that, but it is what it is.
105 additional answers
    2012-12-21T18:32:06+00:00
    Seshnat, you did not read OPs problem very well, they show that they cannot do that, and that does not solve their problem (nor mine).
    Just to bump this thread, will somebody or OP please respond if their is a way to fix this? It is not the WiFi card, I just put a new one in and windows 8 still does not let me turn the wifi "on" even though the card is enabled in the device manager and the machine knows the card is there.
    The first few weeks of windows 8 the wifi was working (unlike the new start menu search that is evil), but now is all messed up. Somebody please help!
    2012-12-21T18:32:59+00:00
    It does not display a wifi connection for me to highlight. What do I do, people?
    2012-12-21T22:51:15+00:00
    techthrowaway
    I had the same problem. For me the following worked: 1) reboot the system in "Safe Mode, Network enabled", 2) turn WiFi on (for some reason this option was enabled in safe mode), 3) restart the system in normal mode - vous a la!
    2012-12-22T16:27:48+00:00
    One of the frustrating things I have had with Windows 8 is the WiFi connection of my desktop computer. I am using Zonet USB wireless card (model ZEW2590, made by Ralink) and it had worked perfectly with Windows 7 until I upgraded to Windows 8 a couple of months ago. The problem is that every time after the computer wakes up from sleep mode or being re-booted, the wireless connection is lost. The wireless status always shows: limited. The driver is deemed up to date (despite driver date as 4/13/2012) per Windows 8 automatic update check. I always try all kinds of diagnoses and auto fixes. After 15 minutes or so, the connection will come back while I don't know which step has helped. By the way, my power setting for wireless adapter is "Maximum Performance".
