Wifi Toggle switch is greyed out
2012-11-04T04:04:43+00:00
Original Title: How to turn on WiFi Capability on Windows 8
I upgraded my Laptop Toshiba L500D from Windows 7 Home Premium (x64) to Windows 8 Pro (x64) a few days ago, then I realized yesterday I could not connect to WiFi connection. I have tried search on the internet how to fix it, but no luck. Here are the following list I have tried so far:
  1. Update to latest Driver by going to "Device Manager", click right "Realtek RTL8187SE Wireless LAN PCIE Network Adapter" then click "Update Driver Software...".
  2. Go to Toshiba Website, download "Realtek Wireless Lan Driver" for Windows 7 (x64) and install it by running in Windows 7 compatibility mode.
  3. Go to BIOS, by pressing F2 before Windows 8 loaded, and enable Wireless Communication.
  4. Troubleshooting "Network Adapter (WiFi)" and it gave this advice:
           "Turn on wireless capability
Use the switch on the front or side of the computer,            or function keys if available,            to enable wireless capability on this computer."
  1. Go to Settings -> Change PC Settings -> Wireless, and I got this:
http://img694.imageshack.us/img694/2959/62721723.png
How am I suppose to switch it on, if the switch is disabled? The airplane is also off, so I suppose the Wireless switch should be enable so I can turn it on and off, but no, the wifi switch is still disabled.
Any advice will be appreciated.
Cheers,
simply.puzzle
2012-11-29T21:38:42+00:00
I had a similar issue.. I used the diagnostics to resolve the issue... here are the steps I took.
  1. Right Click network icon in taskbar and select "open network and sharing center"
  2. highlight wifi connection then at top click "diagnose this connection"
the troubleshooter will discover that the WiFi connection is turned off and offer a "apply fix" option click that and windows will enable the wifi connection...
I had the same issues as the OP and Geecat where the Fn switch just didn't work, so I worked through it as outlined above... Looks like with Win 8 the troubleshooter is even more necessary... Not sure how I feel about that, but it is what it is.
105 additional answers
    2013-11-22T15:44:48+00:00
    I am also facing same problem ...
    Didn't understandng wat happend to it ..Any one help .....wifi nd wimax driver also installed on this
    Hp pavillion dm4 3055dx ....plz help ....
    2013-12-07T12:30:24+00:00
    Hey Guys!
    Good News For You after long struggle i have found a solution that is simply update BIOS.
    I am using HP and I got same problems after installing windows 8. Yesterday after updating BIOS version Problem automatically Solved.
    So download new and Updataed BIOS drivers from manufacturer sites and install to get rid of the problem.
    Regards.
    Taimoor Hassan
    Nice.. I use Lenovo u410, even though in the official site there is no bios update for windows 8, I still updated anyway (with windows 7 bios) it worked awesomely perfect!
    2014-02-25T16:15:26+00:00
    Depending on the laptop model, if your radio is disabled you can enable it with the radio function key, typically this can be either function key (FN) 2 or 3. It will look like a radio tower broadcasting, hope this helps :-).
    2014-03-03T16:38:22+00:00
    Press Fn button then press F1, F2, F3 and so on until Wi-Fi switch is high lighted. Turn switch on then go from there.
