I get “Your PC needs to be repaired” and “Error code: 0xc0000225” in Windows 8.
2012-11-01T06:42:41+00:00
When I boot my Windows 8 laptop (see details below), it displays this message:
Recovery
A required device isn't connected or can't be accessed.
[ A text saying I should use recovery tools on my installation media to fix the issue. ]
Press Enter to try again
Press F8 for Start-up Settings
Press Esc for UEFI Firmware Settings
If I press Enter or F8, the central part of the message changes to:
The application or operating system couldn't be loaded because a required file is missing or contains errors.
File: \Windows\system32\winload.efi
My specific situation:
I have an ASUS UX32VD (R4002H) bought just days ago with Windows 8 preinstalled. I was going to swap the internal HDD for an SSD and was messing with the partitions to make them fit into the smaller SSD before cloning. I am not sure exactly what operation I did prior to the crash, but I probably tried to move a partition (which probably was unnecessary anyway).
I have not made recovery disks (yeah, I know).
When I started SystemRescueCD on the laptop and ran testdisk (for the first time in my life), the partitions seemed OK (to my eye), except for something called Backup Boot(sector|loader|?) that was marked as Bad on one of the partitions. I fixed that, to no avail.
I have no physical representation of a serial number (is that a thing of the past?) and I don't know anything about it being somewhere on the disk. I have no installation media, I didn't get anything like that with the computer.
I have contacted ASUS support, but the answer wasn't very technical.
My obvious question:
How can I get out of this mess? I would prefer if I could repair the partition table or whatever is wrong and get back into the installed OS, but if that is not possible, how can I reinstall Windows 8?
If I need to run a system repair distro from a USB stick and run command line programs, that's no problem.
Thanks!
Original title : I get “Your PC needs to be repaired” and “Error code: 0xc0000225” in Windows 8: how can I fix it?
Update:
I have resolved this issue. What I did was a combination of the advice on this page:
http://qliktips.blogspot.se/2012/11/fix-windows-8-boot-issue.html
and setting the correct attributes and properties on the various partitions and volumes using FDISK. I had a strange partition that I removed and one or more volumes was of the wrong type (GUID).
Windows for home | Previous Windows versions | Install and upgrade
2012-11-07T05:44:31+00:00
Boot from a Windows 8 Recovery Media...
    Trouble Shoot -> Advanced Options -> Command Prompt
            CMD> bootrec /scanos
            CMD> bootrec /rebuildbcd
            CMD> bootrec /fixmbr
            CMD> bootrec /fixboot
     Reboot.
47 additional answers
    2014-09-26T15:50:19+00:00
    Me daba el mismo error lo realice desde adentro del sistema operativo windows 8, configuracion, cambiar configuracion , uso general, quitar todo y reinstalar windows.
    saludos
    2014-12-03T18:49:52+00:00
    Could you tell me exactly what you did?
    My case is similar to yours.
    Thanks!
    2014-12-03T19:09:31+00:00
    The link that helped me was this one:
    https://social.technet.microsoft.com/Forums/windows/en-US/29a3ccc5-636e-421e-8b19-8253c4d79243/winloadexe-is-missing-or-corrupt-recover-cd-does-not-boot-problem-solved?forum=itprovistasetup
    in my case the boot file BCD has been destroyed. I had to do the steps as mentioned in the above link and with a little bit of attention i got it right.
    Good luck!
    2015-01-27T20:22:40+00:00
    I have the same problem as above but when I press enter or F8 nothing happens, need some help please.
