Boot from a Windows 8 Recovery Media...
Trouble Shoot -> Advanced Options -> Command Prompt
CMD> bootrec /scanos
CMD> bootrec /rebuildbcd
CMD> bootrec /fixmbr
CMD> bootrec /fixboot
Reboot.
When I boot my Windows 8 laptop (see details below), it displays this message:
Recovery
Your PC needs to be repaired
A required device isn't connected or can't be accessed.
Error code: 0xc0000225
[ A text saying I should use recovery tools on my installation media to fix the issue. ]
Press Enter to try again
Press F8 for Start-up Settings
Press Esc for UEFI Firmware Settings
If I press Enter or F8, the central part of the message changes to:
The application or operating system couldn't be loaded because a required file is missing or contains errors.
File: \Windows\system32\winload.efi
My specific situation:
I have an ASUS UX32VD (R4002H) bought just days ago with Windows 8 preinstalled. I was going to swap the internal HDD for an SSD and was messing with the partitions to make them fit into the smaller SSD before cloning. I am not sure exactly what operation I did prior to the crash, but I probably tried to move a partition (which probably was unnecessary anyway).
I have not made recovery disks (yeah, I know).
When I started SystemRescueCD on the laptop and ran testdisk (for the first time in my life), the partitions seemed OK (to my eye), except for something called Backup Boot(sector|loader|?) that was marked as Bad on one of the partitions. I fixed that, to no avail.
I have no physical representation of a serial number (is that a thing of the past?) and I don't know anything about it being somewhere on the disk. I have no installation media, I didn't get anything like that with the computer.
I have contacted ASUS support, but the answer wasn't very technical.
My obvious question:
How can I get out of this mess? I would prefer if I could repair the partition table or whatever is wrong and get back into the installed OS, but if that is not possible, how can I reinstall Windows 8?
If I need to run a system repair distro from a USB stick and run command line programs, that's no problem.
Thanks!
Original title : I get “Your PC needs to be repaired” and “Error code: 0xc0000225” in Windows 8: how can I fix it?
Update:
I have resolved this issue. What I did was a combination of the advice on this page:
http://qliktips.blogspot.se/2012/11/fix-windows-8-boot-issue.html
and setting the correct attributes and properties on the various partitions and volumes using FDISK. I had a strange partition that I removed and one or more volumes was of the wrong type (GUID).
Reboot.
I had the exact same problem 0xc0000225, since I moved my OS from HDD to SSD
I tried the diskpart solutions I found on the net, reinstalling... Nothing worked
For that specific problem, this solution worked :
When you can choose your volumes/partitions where you will install, check all the EFI partitinos that could be remaining from a previous Windows installation. If you find one, delete it brutally ;)
The 0xc0000225 will disapear after deleting this old partition.
Worked just as well on Windows 10 after upgrading to SSD!
Reboot.
I did not work.
Reboot.
So , how do i do this? Will this fix it?
