MTP USB Device Drivers will not install correctly for Samsung Galaxy S3- Windows will not sync Galaxy S3 to computer
2012-07-29T17:44:13+00:00
Windows will not sync Galaxy S3 will not sync computer to cell phone.  When I attach USB cable the computer flashes new hardware added but when you click on icon it goes in loops.  I've uninstalled and reinstalled Kies drivers and still the same problem.  All the other cell phones synced to computer including my iPhone but the Samsung Galaxy S3 won't no matter what I do.  When I open Kies and attach the USB cable there's no reconition of the cell phone.  I did see an error Code 31 show up in devices though.
Add Hardware Wizard shows.....
      SAMSUNG Mobile MTP Device  (has the yellow excamation sign)
              This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
      SAMSUNG Android ADB Interface
               This device is working properly
      SAMSUNG Mobile USB Modem
              This device is working properly.
      SAMSUNG Mobile USB Composite DeviceThis device is working properly.
This is about all the information I can give right now.  I forgot to mention that I'm running Windows XP I hope that helps too.  With all said I don't understand why the drivers required for this device won't load.  Any help or suggestions will be greatly appreciated.  Thanks all
2012-07-30T12:57:25+00:00
  • What is the version of the driver that you are using?
The most current version Is ver.v1.4.6.0 released June 19, 2012.
I would recommend you to please update the USB drivers on your computers and check if it helps.
How to manage devices in Windows XP
http://support.microsoft.com/kb/283658
If this does not help you, I would recommend you to please contact Samsung support for better assistance.
http://www.samsung.com/us/support/
There is a community forum for Samsung where you can post questions.
http://www.samsung.com/us/support/owners/product/SCH-I535MBCVZW
Hope this information helps.
43 additional answers
    2014-09-21T02:36:40+00:00
    HERE's THE SOLUTION:
    1. Go to the Registry Editor (Start --> Run --> "regedit" --> [ENTER])
    2. Search the following key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\
    3. If you click one of the few subkeys in class (e.g. {4D36E965-E325-11CE-BFC1-08002BE10318}) you'll find the string value (Standard) on the right side with a value (e.g. DVD/CD-ROM-Drives)
    4. You have to find the value "Portable Devices" on the string value (Standard) (In my case {EEC5AD98-8080-425f-922A-DABF3DE3F69A}, but I don't know if they are called always the same.
    5. Once found, you see a string value called UpperFilters --> DELETE IT!
    6. Finished!  Now your Samsung Mobile MTP Device should be recognized and even installed correctly right away. (The name of the device changed to GT-I9100 (Devicemanager) in my case...)
    Here an explanation about UpperFilters and LowerFilters if you want to know more: http://djlizard.net/2007/04/30/230/
    Maybe this short tutorial can save you some time... =)
    2014-09-22T08:39:32+00:00
    Here is how I fixed it...
    1. Go to the Registry Editor (Start –> Run –>type in, “regedit” (without the quotes) then click OK.
    3. Go upto Edit>Find, type in or copy/paste Portable Devices
    4. In the right hand pane you will see the (Default) value “Portable Devices” on the string
    5. Once found, you see a string value called UpperFilters –> delete it!
    6. Finished!
    2014-09-22T08:40:53+00:00
    6. Finished!
    Thanks, but it's usfull for PTP only but MTP not!
    Can u help me for MTP solution?
    2014-09-22T08:49:32+00:00
    6. Finished!
    it's good for PTP ... BUT MTP nothing happend !! same problem.
