What program is Strong Vault connected to?
2012-10-09T08:58:09+00:00
I thought that Strong Vault was something I did not need and tried to delete it....I deleted whatever program it was linked to though.....embarASSing to have to ask this question :(   I rethought the situation though and thought maybe it is best to keep it....It have been deleted or rather the program that Strong Vault is connected to is gone and Strong Vault still pops up and tries to backup the files of where I am trying to get to...and I have to click on the cancel button several times to get it to stop the process it can't complete...Did I make a big GOOF or what.....SOS SOS...EmbarASSingly....I would praise the person who can help me FOREVER!!! Should it reinstall it or them??? SOS IF NOT, I need help to get it deleted...I am so confused that now I am making a mess of my question....Thank You Very Much  signed ...I own up to my mistake ...I feel VERY foolish....Laugh at me if you will rabbit said Elmer Fudd....Hey! maybe I should use that for my internet username!!  FUDD!! ( Forever Doing Dumbness) !!  Seriously...somebody please take pity on the elderly!!!
Windows for home | Other | Apps
2012-11-06T08:29:14+00:00
This program is holding some virus like qualities. You are not allowed to install a free version only a paid one, when the program sneaks in through something else it'll force you to see an error everytime you turn on your computer.
Nice try Craig. I found a fix and felt it was important to post; http://support.microsoft.com/mats/program\_install\_and\_uninstall click on this link and click run, let it troubleshoot for you but you select the files to delete (something along the lines of that, it was the second option) after that is done it will show you guessed it "StrongVault" or "Strong Hold" click on that and let it uninstall and clean up. Restart your computer you will be good to go.
The link provided does not install anything I checked. It is also through Microsoft. Let me know if this helps!
Last Craig, cut your **** if when your program is searched in google and the first link is to uninstall you seemingly screwed up. First time posting thought I would help. Gabe.
2012-11-18T18:02:17+00:00
I suddenly found this "strongvault" program on my computer after installing "VLC Media Player".  It has caused havoc.  I now have error messages when I am trying to open important programs for mmy business.  It has also caused a fatal error and has stopped "SOS messaging from working.  Anybody know what I can do about this.  Why don't the people at "Strongvault" or Stronghold, or whoever they are have a large box asking whether you want to install their program before allowing it to just try to commandeer your system??? Some programs now tell me the data cannot be found and has been moved to a different location.  I believe this may have legal ramifications, since the moved information is propriety and confidential... I need immediate help before I contact the legal channels for this mess.  I hope the folks at microsoft can help!
We do not do anything that would cause files from other programs to be moved or deleted. It sounds as though the messages you are seeing are referring to the Strongvault uninstaller not being found, which is part of the Windows installer glitch others have reported in this thread. Use Microsoft's FixIt app first to try and resolve the problem:
http://support.microsoft.com/mats/program_install_and_uninstall
<Removed>
If you are still having problems after trying both of these, please contact me directly at craig[at]stronghold.com with as many details as possible on what you are experiencing.
Thanks.
Craig
2012-10-09T15:33:26+00:00
Hi Penney,
Which version of Windows are you using?
You can do a system restore to before you deleted the program:
For XP
http://support.microsoft.com/kb/306084
For Vista
http://windows.microsoft.com/en-US/windows-vista/What-is-System-Restore
For Windows 7
http://windows.microsoft.com/en-US/windows7/products/features/system-restore
Also, if this is the Strong Vault you are talking about, here is instructions on how to remove it:
http://strongvaultfree.com/pages/uninstall
Hope this helps!
205 additional answers
    2013-02-11T15:32:38+00:00
    Are you kidding?  Seriously?  This has been an Major issue for far too long.  After 14 pages of 140 replies, there still is no solution?  Seriously?  Now I'm supposed to become a program.  No.
    Every install, including MICROSOFT SECURITY UPDATES prompts to re-install this damn program.  Maybe, just maybe this is why Microsoft products are not preferred.  This link "provided by Microsoft" did absolutely NO help what-so-ever!  http://support.microsoft.com/mats/program_install_and_uninstall
    Do NOT Tell Me To Install Another Microsoft Product Just To Get Rid Of This Problem You Created!  When Will This Get Fixed?
    This is NOT specifically targeted to a single person but the entire company that created StrongVault!  Seriously.
    2013-02-11T15:39:03+00:00
    "Dr. Groovy"? Are these directories/files to be deleted? And safely? What repercussions will occur?
    ***** Important ****
    Strongvault was found in the following folder locations after running the uninstaller provided by Microsoft i.e.  http://support.microsoft.com/mats/program_install_and_uninstall
    The method to discover the folder locations below was the result of a couple simple commands ented at the Command Prompt (see below).  Navigate to the top or root of the system drive (the drive where Microsoft Windows installs).  Find more great how-to tips at Groovypost.com
    Note: The /s option will search every subfolder below the current folder of the Command Promptl.
    Use the following commands to find almost any file on your System
    Open Command Prompt and type the following:
    **cd \ <**press enter>
    c:&gt; dir strong* /s  <press enter>
    Directory of C:\Users\All Users
    2/11/2013  05:08 AM    <DIR>          Strongvault Online Backup
                  0 File(s)              0 bytes
    Directory of C:\Users\phillip\AppData\Local\Microsoft\Windows\Temporary Interne
     Files\Content.IE5\5T8KHG2V
    2/11/2013  05:08 AM            13,714 strongvaultfree_com[1].htm
                  1 File(s)         13,714 bytes
     Files\Content.IE5\ABQQ93LO
    2/11/2013  05:09 AM            43,183 strongvault_com[1].htm
                  1 File(s)         43,183 bytes
    Directory of C:\Users\phillip\AppData\Local\Temp\is416908330
    2/06/2013  03:10 PM        12,365,576 Strongvault.exe
                  1 File(s)     12,365,576 bytes
    Directory of C:\Users\phillip\AppData\Roaming
    2/10/2013  06:11 PM    <DIR>          Strongvault
                  0 File(s)              0 bytes
    Directory of C:\Users\phillip\AppData\Roaming\Strongvault
    2/10/2013  06:11 PM    <DIR>          Strongvault Online Backup 2.0.0
                  0 File(s)              0 bytes
    Directory of C:\Users\phillip\AppData\Roaming\Strongvault\Strongvault Online Ba
    kup 2.0.0\install\D6C49DB
    2/10/2013  06:11 PM    <DIR>          Strongvault Specific Files
    1/15/2013  04:15 PM         1,404,416 Strongvault.msi
                  1 File(s)      1,404,416 bytes
    kup 2.0.0\install\D6C49DB\CommonAppDataFolder
                  0 File(s)              0 bytes
    kup 2.0.0\install\D6C49DB\LocalAppDataFolder
                  0 File(s)              0 bytes
    kup 2.0.0\install\D6C49DB\LocalAppDataFolder\Strongvault\Blinx Distribution
    1/15/2013  04:15 PM           385,320 StrongVaultApp.exe
    1/15/2013  04:14 PM             6,680 StrongvaultApp0.dat
    1/15/2013  04:15 PM           107,304 StrongVaultBrowser.exe
    1/15/2013  04:14 PM            73,216 StrongVaultInfo.dll
                  4 File(s)        572,520 bytes
