What program is Strong Vault connected to?
2012-10-09T08:58:09+00:00
I thought that Strong Vault was something I did not need and tried to delete it....I deleted whatever program it was linked to though.....embarASSing to have to ask this question :(   I rethought the situation though and thought maybe it is best to keep it....It have been deleted or rather the program that Strong Vault is connected to is gone and Strong Vault still pops up and tries to backup the files of where I am trying to get to...and I have to click on the cancel button several times to get it to stop the process it can't complete...Did I make a big GOOF or what.....SOS SOS...EmbarASSingly....I would praise the person who can help me FOREVER!!! Should it reinstall it or them??? SOS IF NOT, I need help to get it deleted...I am so confused that now I am making a mess of my question....Thank You Very Much  signed ...I own up to my mistake ...I feel VERY foolish....Laugh at me if you will rabbit said Elmer Fudd....Hey! maybe I should use that for my internet username!!  FUDD!! ( Forever Doing Dumbness) !!  Seriously...somebody please take pity on the elderly!!!
Windows for home | Other | Apps
2012-11-06T08:29:14+00:00
This program is holding some virus like qualities. You are not allowed to install a free version only a paid one, when the program sneaks in through something else it'll force you to see an error everytime you turn on your computer.
Nice try Craig. I found a fix and felt it was important to post; http://support.microsoft.com/mats/program\_install\_and\_uninstall click on this link and click run, let it troubleshoot for you but you select the files to delete (something along the lines of that, it was the second option) after that is done it will show you guessed it "StrongVault" or "Strong Hold" click on that and let it uninstall and clean up. Restart your computer you will be good to go.
The link provided does not install anything I checked. It is also through Microsoft. Let me know if this helps!
Last Craig, cut your **** if when your program is searched in google and the first link is to uninstall you seemingly screwed up. First time posting thought I would help. Gabe.
2012-11-18T18:02:17+00:00
I suddenly found this "strongvault" program on my computer after installing "VLC Media Player".  It has caused havoc.  I now have error messages when I am trying to open important programs for mmy business.  It has also caused a fatal error and has stopped "SOS messaging from working.  Anybody know what I can do about this.  Why don't the people at "Strongvault" or Stronghold, or whoever they are have a large box asking whether you want to install their program before allowing it to just try to commandeer your system??? Some programs now tell me the data cannot be found and has been moved to a different location.  I believe this may have legal ramifications, since the moved information is propriety and confidential... I need immediate help before I contact the legal channels for this mess.  I hope the folks at microsoft can help!
We do not do anything that would cause files from other programs to be moved or deleted. It sounds as though the messages you are seeing are referring to the Strongvault uninstaller not being found, which is part of the Windows installer glitch others have reported in this thread. Use Microsoft's FixIt app first to try and resolve the problem:
http://support.microsoft.com/mats/program_install_and_uninstall
<Removed>
If you are still having problems after trying both of these, please contact me directly at craig[at]stronghold.com with as many details as possible on what you are experiencing.
Thanks.
Craig
2012-10-09T15:33:26+00:00
Hi Penney,
Which version of Windows are you using?
You can do a system restore to before you deleted the program:
For XP
http://support.microsoft.com/kb/306084
For Vista
http://windows.microsoft.com/en-US/windows-vista/What-is-System-Restore
For Windows 7
http://windows.microsoft.com/en-US/windows7/products/features/system-restore
Also, if this is the Strong Vault you are talking about, here is instructions on how to remove it:
http://strongvaultfree.com/pages/uninstall
Hope this helps!
205 additional answers
    2012-11-21T01:56:03+00:00
    Agreed-Strongvault is like malware ... I didn't sign up ... uninstall fyi-seems like it is gone ... but itis attached to all of your programs causing issues ...
    2012-11-21T03:16:48+00:00
    GabeJRuiz's posting of the Microsoft link:
    was all the help I needed.
    I followed the link, read and followed the very simple and clear instructions, and within a few moments the FixIt program analyzed my problem and offered me the choice of solutions.
    A damaged registry key contained a remnant link to the StrongVault installer, all of which was deleted and fixed by the Microsoft Fixit Center.
    "Thank You", Gabe J Ruiz, for the only working solution currently available on the 'net.
