how to: copy a CD to another CD which is blank
2012-01-20T16:03:44+00:00
Original Title**: where is the "disk copy" command?**
Using Windows Explorer (in Windows 7 64Pro) I see no familiar "disk copy" command to automatically make a backup copy of a CD or DVD that is currently in my DVD burner.  How can I use Windows Explorer to copy a disk that is in the D: (DVD) drive?
(I have tried various combinations of this question in the Help menu installed with Win 7 w/o any answer that remotely addresses this very simple [and I must assume common] question....similarly, I found no answer at the Windows 7 home page...)
2012-01-20T16:48:41+00:00
Diskcopy is a DOS facility. Since Windows arrived some 25 years ago, you do these things with a graphical user interface rather than with a command.
Open two Windows Explorer frames, then drag the DVD item to wherever you want it on your hard disk. That's all.
Günter Born 49,461 Reputation points
2012-01-20T17:09:13+00:00
Beside the answer given by Pegasus - as far as I remember, discopy has been removed als context menu command in Windows 7 (because it was only used for floppy discs in previous Windows versions).
2012-01-20T22:05:21+00:00
Ok...upon further investigation, I suppose the only way to perform a "disc copy" to to drag all the contents of the CD to a folder set up for that purpose on C:, remove the original CD, insert a blank CD, drag all the files back to D: and click: "Burn to Disc"...a bit more cumbersome but workable...and, I did spell disc as disk....so, I need to be more careful with my questions...
Windows 7 does not have a direct "CD Copy" function but some third-party programs do, e.g. ImgBurn (www.imgburn.com).
40 additional answers
    2017-07-03T10:22:54+00:00
    I'm in the same boat.  Some others are helping me - I know it can be done, amazing that it is so difficult.  If I get answers, will share with you.    Tony
    It's not difficult at all. I had never done it before myself but found the solution within a few seconds by asking Google like so:
    how to copy a music cd wmp 12
    You're actually making life more difficult for yourself by appending your question to someone else's answered post which is 5 years old (!), half a mile long, has meandered far and wide and does not really deal with your topic. Creating a new post under the heading How to copy a music CD would have gotten you several highly specific answers in no time at all.
    Since Windows Media Player (WMP) looks quite different from one version to the next I shall not post a recipe here. I recommend you find out which version you have, then check the web with a search phrase like the one above. If still confused, come back here to get more hints from this 73 year old codger.
    2017-07-03T13:03:44+00:00
    No help with windows 10
