how to: copy a CD to another CD which is blank
2012-01-20T16:03:44+00:00
Original Title**: where is the "disk copy" command?**
Using Windows Explorer (in Windows 7 64Pro) I see no familiar "disk copy" command to automatically make a backup copy of a CD or DVD that is currently in my DVD burner.  How can I use Windows Explorer to copy a disk that is in the D: (DVD) drive?
(I have tried various combinations of this question in the Help menu installed with Win 7 w/o any answer that remotely addresses this very simple [and I must assume common] question....similarly, I found no answer at the Windows 7 home page...)
2012-01-20T16:48:41+00:00
Diskcopy is a DOS facility. Since Windows arrived some 25 years ago, you do these things with a graphical user interface rather than with a command.
Open two Windows Explorer frames, then drag the DVD item to wherever you want it on your hard disk. That's all.
Günter Born 49,461 Reputation points
2012-01-20T17:09:13+00:00
Beside the answer given by Pegasus - as far as I remember, discopy has been removed als context menu command in Windows 7 (because it was only used for floppy discs in previous Windows versions).
2012-01-20T22:05:21+00:00
Ok...upon further investigation, I suppose the only way to perform a "disc copy" to to drag all the contents of the CD to a folder set up for that purpose on C:, remove the original CD, insert a blank CD, drag all the files back to D: and click: "Burn to Disc"...a bit more cumbersome but workable...and, I did spell disc as disk....so, I need to be more careful with my questions...
Windows 7 does not have a direct "CD Copy" function but some third-party programs do, e.g. ImgBurn (www.imgburn.com).
40 additional answers
    2017-07-02T16:41:25+00:00
    Where did the file come from? The file with the .wpl extension IS NOT an audio file.  Put the CD that has the file on it into the drive, open File Explorer, right-click on the CD drive and select "Open."  You'll be able to see the file(s) on the CD and determine the format.
    2017-07-02T18:53:49+00:00
    Does anyone have the name of an operating program that actually works with out getting a dozen or so non working apps. I'm, about ready to ditch windows 10. I cannot, fantom an organization that makes changes that are useless to the non geek. They should be making things simpler, rather than making things impossible to use. I have been trying since Feb 2017, when I had to buy a new computer, but of course it had WINDOWS 10. I have yet understood a thread, the tried to tell me how to make a back up disc or any other disc.
