how to: copy a CD to another CD which is blank
2012-01-20T16:03:44+00:00
Original Title**: where is the "disk copy" command?**
Using Windows Explorer (in Windows 7 64Pro) I see no familiar "disk copy" command to automatically make a backup copy of a CD or DVD that is currently in my DVD burner.  How can I use Windows Explorer to copy a disk that is in the D: (DVD) drive?
(I have tried various combinations of this question in the Help menu installed with Win 7 w/o any answer that remotely addresses this very simple [and I must assume common] question....similarly, I found no answer at the Windows 7 home page...)
2012-01-20T16:48:41+00:00
Diskcopy is a DOS facility. Since Windows arrived some 25 years ago, you do these things with a graphical user interface rather than with a command.
Open two Windows Explorer frames, then drag the DVD item to wherever you want it on your hard disk. That's all.
Günter Born 49,461 Reputation points
2012-01-20T17:09:13+00:00
Beside the answer given by Pegasus - as far as I remember, discopy has been removed als context menu command in Windows 7 (because it was only used for floppy discs in previous Windows versions).
2012-01-20T22:05:21+00:00
Ok...upon further investigation, I suppose the only way to perform a "disc copy" to to drag all the contents of the CD to a folder set up for that purpose on C:, remove the original CD, insert a blank CD, drag all the files back to D: and click: "Burn to Disc"...a bit more cumbersome but workable...and, I did spell disc as disk....so, I need to be more careful with my questions...
Windows 7 does not have a direct "CD Copy" function but some third-party programs do, e.g. ImgBurn (www.imgburn.com).
40 additional answers
    2017-07-01T00:58:48+00:00
    I find it interesting - you are apparently unable to write a reply which someone with limited computer skills can understand or use.  OK, it is done with a gui rather than a command ...
    So if I open a Window Explorer frame, I have to put the CD I want to copy from into my laptop, and it reads it and puts it - - where?  Then I open a 2nd WE frame - assume I have get the 2 frames to appear side by side on my screen, and then theoretically I could drag the disc contents to ... where?
    And at what point do I take out the 'from' cd and insert the to' cd.
    Yes, MS OS systems can be frustrating - if there was ANY alternative, I would abandon MS, Bing and all the rest of it in a heartbeat.  But some of your replies are equally vague, frustrating and unhelpful ...
    2017-07-01T09:53:06+00:00
    You are apparently unable to write a reply which someone with limited computer skills can understand or use.
    There are several ways to encourage a volunteer forum respondent to explain in detail how to solve a specific problem, e.g.
    • By asking "Could you please post a full step-by-step description of your method?"
    • By posting a derogatory comment such as "You are apparently unable to write . . ."
    You need to decide for yourself which method might give you better results.
