.net framework 3.5 installation error code 0x800f0922
2012-11-03T03:18:56+00:00
I tried to update the .net framework 3.5 on my windows 8 but I keep getting this error code 0x800f0922. I tried all the methods I can find on the internet but I still cannot solve the problem. pls help.
2015-01-29T16:18:55+00:00
I HAVE THE SOLUTION!
Go to Control Panel/System and Security/Action Center
There is a title: "Review recent messages and resolve problems"
Under that I had three warnings. Than I turned everything on.
After that I was able to install .net 3.5 without the 0x800f0922 error code.
Use the
Control Panel | Programs and Features | Turn Windows features on or off.
solution.
I hope it works for everyone with this.
2015-04-18T16:32:23+00:00
I had the same issue but updating the Group Policy Setting under administrative tab helped...
Refer to Method 2: Configure the Group Policy setting in .. https://support.microsoft.com/en-us/kb/2734782/
Hope someone can save some time..
92 additional answers
    2012-11-03T16:24:57+00:00
    I have tried both "turning features on" and "dism" methods but still getting the error.
    2012-11-03T15:50:17+00:00
    Hi MelvinNg,
    I understand that you are unable to install .net framework 3.5 and get error 0x800f0922.
    Let me know if I have misunderstood.
    1. How are you trying to install the .net framework 3.5?
    2. Did you make any changes on the computer prior to the issue?
    3. What are the troubleshooting methods you have tried?
    I would suggest you to install it using the Turning Windows features on or off in Control Panel option or dism command.
    Refer the information starting from the section Enabling the .NET Framework 3.5 in Control Panel in the site:
    Installing the .NET Framework 3.5 on Windows 8
    http://msdn.microsoft.com/en-us/library/hh506443.aspx
    Hope this helps. If the issue persists, let us know and we would be glad to help you.
