Win XP: System Suddenly Keeps Restarting Indefinitely ??
2012-10-03T00:48:00+00:00
Original Title: Win XP: System Suddenly Keeps Restarting Indefinitely ??
Hello;
I’ve browsed through relevant posts with similar titles, but couldn’t find a direct answer to the problem.
Most likely I missed the answer somewhere, and I hope you don’t mind.
Here’s a summary including my unsuccessful attempts.
1) Following 2 automatic updates earlier today:
... a. Microsoft Security Essentials Update (sounds different than the regular Definition Update!)
... b. Windows Malicious Software Removal Tool
the computer keeps restarting indefinitely!
I can’t even delete those latest updates, assuming I can specifically identify them and assuming they’re the culprit!
2) Pressing the power button, Windows starts, and I log on with my user name.
The system continues with the desktop icons and the status bar is partially displayed.
Then the error message:
“Microsoft Security Client
An error has occurred in the program during initialization .... ”
OK
After few seconds whether I press OK or not, the system automatically restarts, and restarts, and restarts, ....
3) I shut down the computer and pressed the power button.
Then F8:: Windows Advanced Options Menu
and I selected Last Known Good Configuration
Didn’t solve the continuing automatic restart problem.
4) I tried F8 and selected Disable Automatic Restart on System Failure
I got the a blue screen with lot of stuff, including:
“A problem has been detected and Windows has shut down to prevent damage to your computer”
“Restart your computer. If this screen appears again, run a system diagnostic utility. In particular, run a memory check and check for faulty or mismatched memory.”
“Contact technical support group for further assistance.”
"Technical information:
*** STOP: 0X0000007F (0X00000000, 0X00000000, 0X00000000, 0X00000000)
Tried my best. No solution.
5) I tried F8, and selected Safe Mode.
First: I selected YES to proceed to work in Safe Mode.
........ No automatic re-starting, but Windows is running in Safe Mode.
........ I turned off the computer.
6) I repeated 5 above in a Safe Mode, but selected NO to use System Restore to restore to a previous date.
I selected Sep 30, 2012 as the Restore Point.
The system progressed, shut down, restarted, I logged on, etc., then the automatic restarting started!
7) I tried F8, and selected the option Directory Services Restore Mode (Windows domain controllers only)
(I was encouraged by the word Restore in the option!)
I got the message:
... Windows XP Home Edition
... The Volume is Clean.
... Windows is running in Safe Mode.
I selected YES, and there was NO automatic restarting, but Windows is running in Safe Mode.
I selected NO, and specified the Restore Point Set 30, 2012. The automatic restarting began within few seconds!
Your advice and help would be greatly appreciated.
Monir
2012-10-21T16:19:19+00:00
Hi;
Thank you Robear for your help and suggestions.
I’m fully satisfied with MS solution to the problem (my post 10/19/2012 9:20 am):
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/win-xp-sp3-safe-mode-windows-updates-server-checks/99b2d552-4c72-40a5-a889-6cdac25cc462?page=2#LastReply
As I reported earlier, I don’t know precisely what MS did or didn’t do upon their remote access to the PC, whether the problem/conflict was apparent to them, how much the MSE latest update package KB2754926 contributed to the problem or it was the problem, whether re-establishing access to Windows Updates corrected the problem, whether there was a malicious and hidden malware only MS in-house special tools could detect and remove while my 3 advanced scanners and MSE couldn’t, or perhaps there was an out-of-sequence or missing KB, ...
I’m hopeful MS will provide some details at some point.
In conclusion, thank you ALL for your generous time and thoughtful replies.
Regards.
Monir
55 additional answers
    2012-10-03T17:43:20+00:00
    Thank you for providing the response in detail.
    I would suggest you to try to boot to safe mode and check if you face the same issues.
    A description of the Safe Mode Boot options in Windows XP: http://support.microsoft.com/kb/315222
    If it’s work fine with safe mode then I would suggest you to perform clean boot form the safe mode to find out which program is causing the issue.
    How to configure Windows XP to start in a "clean boot" state: http://support.microsoft.com/kb/310353
    Note: Once you are done with the troubleshooting, perform the steps in “Steps to configure Windows to use a Normal startup state “to reset computer as usual.
    Note: If you are still facing the issue then I would suggest you to disconnected all the external devices except mouse and keyboard and check if it helps.
    Refer:
    You receive a "Stop error code 0x0000007F (UNEXPECTED_KERNEL_MODE_TRAP)" error message or your computer unexpectedly restarts: http://support.microsoft.com/kb/822789
    Note: Important this section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: http://support.microsoft.com/kb/322756
    We would suggest you to don’t use the Third Party Software and application which may affect your computer registry and application, you can use disc clean up to delete the temp files.
    General causes of "STOP 0x0000007F" errors: http://support.microsoft.com/kb/137539
    Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
    Note: If you are not sure how to check the RAM settings, I would suggest you to contact the manufacturer or refer to the user’s guide that was included with your hardware.
