How do I change my network location from Public to Home in Win7?
2012-05-04T04:00:34+00:00
On my server I am running Win 7 Pro 64-bit (SP1) with a wired Ethernet connection to my router.
I have several other networked devices in my network including wired and wireless devices,  Win 7 PCs, a Win XP PC, and some other devices such as network backup, and media center.  I am having problems with devices seeing each other (especially my server) and sharing resources (files and printing).
On my server I am able to connect to the internet through my wired connection.  However, in "Network and Sharing Center" under active networks I see "You are currently not connected to any networks."  The link to "Connect to a network" shows that I have no networks to connect to.   When I try to connect to my homegroup or to create a homegroup, I am told "To create or join a homegroup, your computer's network location must be set to Home."  Mine is set to public and I cannot change this as to make this change requires me to click on the Home/Work/Public icon/link in my active network and I do not have any active (or inactive) network.  Therefore there is no link to allow me to get to the "Change Network Location" dialog box.
I have tried trouble shooting the network (no problems found) and the Homegroup troubleshoot (no problems found).
I have considered doing a Win 7 Repair Install to fix whatever network configuation problems I am unable to access.  However, my original disk is an OEM Windows 7 Pro 64-bit without SP1.  Now that my machine has been on SP1 for about a year, it will not allow me to do a Repair Install and the version on my machine is newer (greater) than what is on the installation disk.  Also I considered un-installing SP1 but that also failed.  Some error message about missing files. I even tried the Command Line un-install of SP1 and that also failed.
What can I do to fix this short of a complete wipe of the disk drive and a clean install?
UPDATE: Feb. 13, 2015  -  Finally Fixed!
The post on Jan 28, 2015 by BennyPootron led me to the solution.
In RegEdit, at "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles"  I deleted all the profiles under this (I had three).
Also, at "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\Unmanaged" were three corresponding items which I also deleted.  This cleaned the slate, so to speak, and when I rebooted, I was able to change my network location to Home and then join my Home Group.
Many thanks to BennyPootron for the insight that led to my solution.
2015-02-13T22:13:03+00:00
I don't know if this applies to Windows 7, but it does work in Windows 8 and Windows 10.
  1. Open "RegEdit"
  2. Go to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles"
  3. Locate the Network Location
  4. Change the DWORD Value "Category" to 1
If this doesn't work, delete the key of the network, restart your computer, and repeat.  It should work after that.
Not exactly the answer, but this led to the solution.  FINALLY FIXED!!   Here's how:
In RegEdit, at "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles"  I had three profiles with names such as {4A3BFF36-4EA6-4415-AA5F-46CE449C95AB}.  I tried several things including changing the DWORD value of the item "Category" to 1 in all three of these profiles.  That did NOT work.
However, I eventually deleted all three of the Profiles.
Also, at "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\Unmanaged" were three corresponding items which I also deleted.  This cleaned the slate, so to speak.
THIS WORKED!
When I re-booted, I was able to change my network from Public to Private and it walked me through the process of joining an existing Home Group established by another computer in our household.
Finally nearly 3 years after my original post, I have the problem fixed.
Many thanks to BennyPootron for the insight to a solution.
56 additional answers
    2014-04-09T22:56:36+00:00
    Never mind..it went back "Public (current file)..
    This is so strange..why is it doing that?
    2014-04-11T00:30:52+00:00
    OK.. I found the culprit.
    For anyone having the same problem I am having..if you have Avast, turn off its firewall and just use Windows firewall. It was intercepting the network settings and swtiching them back to Public. I tried chaning the settings within Avast, but they were not saving..even after a "repair" and/or reinstallation.
    2014-04-11T12:19:01+00:00
    I Have avast! Internet Security Installed in my computer, I only can say that after I've used the MS Fix for this problem this not ocurred again, maybe a configuration in firewall or another conf. inside avast that I've change between the problem and the fix?
    Let's keep exchange information to try to solve that and help all.
    2014-04-11T12:37:10+00:00
    I tried the Microsoft Fix many, many times and only once it corrected the problem, but it came back with in a day. I tried changing the settings in Avast, but it did not correct the problem until I disabled the Avast Firewall. I have used Avast for many years and have never experienced this issue.
    I deteremined it was Avast because my wife's computer was having the same issue and I was getting a msg from Windows Maintaencance, about an issue with Avast's firewall. So it was then when I decided to try to disable Avast's Firewall.
    The issue is completelty  gone now. I think it's just the Avast's update that is causing the issue, because like I said, I have never seen this happen with Avast.
