xp pro not booting after changes to boot.ini
2012-06-29T08:25:26+00:00
The problem is my C: partition has Windows 7
D: Has XP Pro
These should be seen as partition 1 and 2 resp. right?
I wanted XP pro to boot first as the default partition.
A few days ago I made a change to the boot.ini file. But since then XP Pro has not been booting at all.
I wanted XP Pro to boot first as the default partition.
Since XP Pro and my D: drive have not been booting, I accessed the boot.ini file through the C: partition, that is Windows 7 and I changed the order (i.e. partition no.) in the boot.ini file and saved it to the necessary location, i.e. D:/WINDOWS/pss/
through my working C: drive, i.e. the Windows 7 partition, but it is still not working because apparently even though I am saving it here, the actual values and partition paths are not actually being changed on the system. I confirmed this by going into the CMD shell switching to D: and running the command D:>bootcfg.
Apparently no matter what values I am saving in the boot.ini file which I am saving as a text file or "All files" in D:/WINDOWS/pss/  it is not actually changing in the system because whenever I run the bootfg command the values are remaining just the same and not being able to be changed, because apparently it is not being saved in XP Pro and the D: partition. No matter what I do and what values I put into the boot.ini file accessed through the windows 7 partition, the values which bootcfg returns to me are always the same and it refuses to change the path name or anything else. Regardless of what commands I put into bootcfg itself also.
These are the values that bootcfg is giving me:
default:multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
Boot entries:
Boot entry ID: 1
OS friendly Name: MS Windows XP Professional
Path: multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
OS Load options: /NOEXECUTE=OPTIN/FASTDETECT /USEPMTIMER
My XP Pro partition is just not booting and it is my primary partition and has all my work. It is imperative that it boots.
My Windows CD is also not booting because apparently my DVD drive is not working properly, I had the anti malware program threatfire (threatfire.com) installed on my D:Windows XP drive but have uninstalled just it in case it was blocking my changes to the system.
On C:Win7 I set the default OS option in the advanced tab to Win7 and on the D:XP Pro to XP Pro , when it was booting and working. Now I can only access my D:XP Pro files thru the C:Win7 drive. But XP just isnt booting. What shd I do? Thks.
2012-07-08T13:06:35+00:00
I do have a windows CD handy but my CD/DVD drive is not reading it and not working properly.
Seems like your initial post stated your cd/dvd isn't working.
With all due respect, you're gonna keep on with these hap hazard fixes and your computer isn't going to boot at all. I am going to try to help you one more time. Please follow closely.
Start your computer by loading Windows 7. Click HERE and download EasyBCD. Install the the software in the trial version. After the installation has completed open EasyBCD. You will see an interface like the image below. Click on Add a new entry.
A new screen will appear as in the image below. Use the drop down menu to select Windows NT/2k/XP/2k3 as shown below. Type the name of the operating system in the field below. Of course this will be Windows Xp (you can add Home or Pro to the name if you want). Now make sure there is a check mark in the box to "Automatically detect correct drive". Once you have completed those steps click "Add Entry". That's it!! You're done. If all went well, and if you followed these instructions carefully it will have, you now have a dual boot system.
You can now begin working on your cd/dvd issue.
43 additional answers
    2012-07-08T22:25:56+00:00
    Wow! Incredible! Amazing! Worked like a breeze! Thanks!
    Now how do I sort out my cd/dvd reader/writer issue? Please, step by step, from the beginning.
    Thanks a lot!
    2012-07-09T01:26:20+00:00
    Please specify your exact brand name of your BIOS. This can be found when you first turn on your computer, the first screen you see.
    -Alex
    2012-07-09T09:51:37+00:00
    Thanks a lot!
    You are welcome. That is the method I was trying to get you to follow all along. Regardless, we are here to help and that issue is now resolved.
    Moving on to your cd/dvd drive.
    Please click HERE. Download DevFilter. Save the file to your desktop. Now double click on the file to run it. In the left pane scroll down to your cd/dvd rom device and click on it. A list of the filters will display in the right pane. Click on "Clipboard" at the bottom of the DevFilter window. The contents of the filters will be copied to your clipboard. Paste the contents in your reply. Example only below. Yours may be slightly different.
    Filter Driver Load Order     http://www.bustrace.com
    Upper Filter Drivers:  No Upper Filter Drivers specified for this device.
           Device Object:  ATAPI iHAP222   9 ATA Device
    Lower Filter Drivers:  No Lower Filter Drivers specified for this device
    Note: Be advised the download will expire after 3 days.
    2012-07-10T07:57:42+00:00
           Device Object:  SONY DVD RW DW-G520A ATA Device
    Ok These are the contents. Now what?
