The error also means that there isn't enought power in the USB port where the device is plugged-in. I would suggest connecting the device to another USB port or use a USB hub that supplies it’s own power.
Check if it helps.
Original Title:USB DEVICS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE
THE USB DEVICS HAS EXCEEDED THE POWER LIMITS OF ITS HUB....POWER SURGE....this is what the error message that was displayed everytime i put my pendrive...so i did something ,the error message stopped but cant use any pendrive...
when i put a pendrive,getting notifications at some ports...but explorer not opening the device..:(:(..Please help
Check if it helps.
Update:
What I had to do was uninstall all USB controllers, restart my computer and then go back to Device Manager and set all my Generic USB ports and USB Root Hub controllers to disallow the computer to turn off the devices to save power by unchecking all four boxes so the message should not appear again. You can complete the latter step by right clicking on all the Generic USB ports and USB Root Hub ports, clicking on properties, clicking on the Power Management tab, and unchecking the box that says "allow this computer to turn off the device to save power". Please note that you will have to uncheck the box for each Generic USB Hub and USB Root Hub port individually to ensure that the message does not return. You may also go to Regedit and follow this path: HKEY_Local_Machine/System/CurrentControlSet/Services/USBCCGP+USBHUB. Under both USBCCGP and USBHUB: Right click and click on New, on the new menu click on DWORD and a New Value field should appear. Now type in this new value field: DisableSelectiveSuspend and hit enter. Finally, click on the newly created DisableSelectiveSuspend field and click Modify; in the Value data box type 1 and press okay. Complete all steps for both USBCCGP and USBHUB.
Have you made any software or hardware changes to your computer prior to this issue?
To work on the issue, refer these methods.
Method 1:
Run the fixit from the following link.
Hardware devices are not working or are not detected in Windows
http://support.microsoft.com/mats/hardware\_device\_problems/en-us
Method 2:
Re-install the USB Controllers.
a) Click Start and type devmgmt.msc, and then press Enter.
b) Expand the Universal Serial Bus Controllerssection.
c) Uninstall each of the devicesunder the USB Controller section by right-clicking on each one, and then clicking Uninstall.
d) Close the Device Manager and restart your computer.
Windows will automatically re-install the USB controllers in your computer, without you having to do anything further. Your computer should now run USB devices properly.
Further,
I would suggest you open the event viewer logs and check for the complete errors.
Refer: Open Event Viewer
http://windows.microsoft.com/en-US/windows7/Open-Event-Viewer
Also refer:
What information appears in event logs (Event Viewer)?
http://windows.microsoft.com/en-US/windows7/What-information-appears-in-event-logs-Event-Viewer
Hope the information is helpful.
ya...i recently upgraded my pc...the configuration is af follows
Intel core I7 processor
GIGABYTE B75M-D3H Motherboard
8GB RAM
2TB+500GB+80GB =Total threeHard disks
500W SMPS
After this only i got this proble
your above solutions didnt help me
note:
When i put my data card,i can connect to internet but the REMOVABLE DISK wasnt shown in my computer(which was shown previously ie b4 upgradation of hardware)
