"Print processor does not exist" What can I do? Printer is a Brother MFC-J430w.
2012-02-12T09:04:59+00:00
I am trying to install a Brother MFC-J430w wireless printer on my 32 bit Dell PC. I've downloaded the driver off the Internet, but I get a prompt saying "Unable to install printer. The print processor does not exist." What should I do?
2012-02-13T03:56:53+00:00
Can you check the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\winprint
At that registry key, in the right window, is "Driver" of the type REG_SZ and is the "Data"  winprint.dll?
Also, check that the winprint.dll exists in the C:\Windows\System32\spool\prtprocs\w32x86 folder.
More info in the following article which is for Windows NT but, in general, should also apply to Windows 7:
http://support.microsoft.com/kb/153355
2012-02-13T11:58:21+00:00
Yes, you could try changing localspl.dll to winprint.dll
Create a System Restore point beforehand and restart the computer afterward.
43 additional answers
    2014-07-18T16:13:49+00:00
    I did but I still get this:
    I have no other hunch that a recent Windows update caused the issue. So, it may be worth noting that an earlier 'big' update is missing from my system. I asked about that here:
    http://answers.microsoft.com/en-us/windows/forum/windows8_1-windows_update/kb2919355-disables-office-2013-x64-in-windows-81/0e73a410-0aea-488f-a8e3-69b1c30fb655
    2014-07-19T04:25:22+00:00
    Can you go to the following folder:
    C:\Windows\System32\spool\prtprocs\x64
    In that folder can you right-click the winprint.dll > Properties > Details
    What is the File version and Size?
    2014-07-19T05:26:24+00:00
    Type  Application extension
    File version
    Product name
    Product version
    Copyright
    Size  43.5 KB
    Date modified 8/22/2013 4:57 PM
    Language
    i.e. File version, and some other data, are not given.
