"Print processor does not exist" What can I do? Printer is a Brother MFC-J430w.
2012-02-12T09:04:59+00:00
I am trying to install a Brother MFC-J430w wireless printer on my 32 bit Dell PC. I've downloaded the driver off the Internet, but I get a prompt saying "Unable to install printer. The print processor does not exist." What should I do?
2012-02-13T03:56:53+00:00
Can you check the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\winprint
At that registry key, in the right window, is "Driver" of the type REG_SZ and is the "Data"  winprint.dll?
Also, check that the winprint.dll exists in the C:\Windows\System32\spool\prtprocs\w32x86 folder.
More info in the following article which is for Windows NT but, in general, should also apply to Windows 7:
http://support.microsoft.com/kb/153355
2012-02-13T11:58:21+00:00
Yes, you could try changing localspl.dll to winprint.dll
Create a System Restore point beforehand and restart the computer afterward.
43 additional answers
    2014-07-13T04:28:49+00:00
    I have the same issue in Windows 8.1 64 bit.
    winprint.dll  is present in: Windows\System32\spool\prtprocs\x64
    In my system the reg key
    has no sub-folder at all. Should I follow the instruction in this key, or create a \winprint ?
    I can change "Data"  winprint.dll but don't know how to set  "Driver" of the typeREG_SZ
    Thanks.
    2014-07-18T03:44:48+00:00
    Hi George,
    Since you are running 64-bit Windows can you check the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments*Windows x64\Print Processors\winprint*
    At that registry key, in the right window, is "Driver" of the type REG_SZ and is the "Data"  winprint.dll ?
    Also, check that the winprint.dll exists in the C:\Windows\System32\spool\prtprocs*x64*folder.
    2014-07-18T12:46:12+00:00
    Hi Auggy,
    In that reg key I have two rows in the right pane:
    (Default)       REG_SZ         winprint.dll
    Driver           REG_SZ         winprint.dll
    As I noted at the beginning, winprint.dll  is present in: C:\Windows\System32\spool\prtprocs\x64
