"Print processor does not exist" What can I do? Printer is a Brother MFC-J430w.
2012-02-12T09:04:59+00:00
I am trying to install a Brother MFC-J430w wireless printer on my 32 bit Dell PC. I've downloaded the driver off the Internet, but I get a prompt saying "Unable to install printer. The print processor does not exist." What should I do?
2012-02-13T03:56:53+00:00
Can you check the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\winprint
At that registry key, in the right window, is "Driver" of the type REG_SZ and is the "Data"  winprint.dll?
Also, check that the winprint.dll exists in the C:\Windows\System32\spool\prtprocs\w32x86 folder.
More info in the following article which is for Windows NT but, in general, should also apply to Windows 7:
http://support.microsoft.com/kb/153355
2012-02-13T11:58:21+00:00
Yes, you could try changing localspl.dll to winprint.dll
Create a System Restore point beforehand and restart the computer afterward.
43 additional answers
    2014-02-12T12:16:03+00:00
    Are you running 32-bit or 64-bit Windows?:
    http://support.microsoft.com/kb/827218
    2014-02-13T05:13:37+00:00
    I am running 64 bit enterprise version
  3. Deleted
