"Print processor does not exist" What can I do? Printer is a Brother MFC-J430w.
2012-02-12T09:04:59+00:00
I am trying to install a Brother MFC-J430w wireless printer on my 32 bit Dell PC. I've downloaded the driver off the Internet, but I get a prompt saying "Unable to install printer. The print processor does not exist." What should I do?
2012-02-13T03:56:53+00:00
Can you check the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\winprint
At that registry key, in the right window, is "Driver" of the type REG_SZ and is the "Data"  winprint.dll?
Also, check that the winprint.dll exists in the C:\Windows\System32\spool\prtprocs\w32x86 folder.
More info in the following article which is for Windows NT but, in general, should also apply to Windows 7:
http://support.microsoft.com/kb/153355
2012-02-13T11:58:21+00:00
Yes, you could try changing localspl.dll to winprint.dll
Create a System Restore point beforehand and restart the computer afterward.
43 additional answers
    2014-07-24T03:47:37+00:00
    Thank you for all.
    2014-07-24T11:32:26+00:00
    You're welcome.
    2016-03-05T22:58:20+00:00
    I know that this is an old thread, but it comes up when searching the web for the solution.
    Anyway, what worked for me is adding the TCP/IP port with the IP address of the device using the Printer Management PRIOR to starting the Brother driver installation wizard.
    So just open Printer Management > go to your Local Server > Ports> Add Standard TCP/IP Port > enter the IP address of the device, and after that install the drivers.
