Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2014-04-20T14:32:22+00:00
    Re-installation of operating system is not possible with the help of Recovery discs. You need to have Installation discs in order to perform a re-installation of the operating system.
    2014-04-26T10:10:46+00:00
    Thank you very much Jeffer_123...... It`s working now !!!
    2014-04-27T09:19:11+00:00
    when ever i try to rename software distribution to sdold...it says the action cant be completed because the file or folder in it is open in another program
    2014-04-27T14:44:51+00:00
    Hi Ankush,
    You can't rename that folder while the Automatic Updates Service is running.
    Click Start, Run and in the box enter:
    services.msc
    Click OK to open the Service Applet.
    Locate the Automatic Updates Service, right click, Properties, Stop and wait for the service to stop.
    Navigate to the c:\windows folder and rename the SoftwareDistribution folder to something you can  remember:
    Rename c:\windows\SoftwareDistibution to something like c:\windows\SD_OLD
    The from the Services applet, you can restart the AU Service manually or just reboot the system and it will start itself.
