Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2014-01-19T18:29:54+00:00
    very suportive thanks
    2014-03-16T16:41:38+00:00
    jessen i am really impressed your knowledge.
    thanks alot
    2014-03-17T07:12:14+00:00
    Hi Saad,
    Glad to know that the issue is fixed. Let us know if you face any issues with Windows in future.
    2014-03-25T15:13:02+00:00
    hi Guys,
    help me ..
    is not found  Run As Administrator?
    and error ..
