Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2013-09-18T11:10:31+00:00
    thanks a million. this have been a headache. it has has worked perfectly
    2013-09-19T01:02:08+00:00
    Hi Noel,
    Glad to know that the issue is fixed. Let us know if you face any issues with Windows in future
    2013-09-19T08:40:03+00:00
    c: Click Start > RunType %windir% and press Enter.
    When I do it there is a error message
    2013-09-20T00:44:06+00:00
    Hi Buddhika,
    Method 1: End the process from task manager and check if that helps, steps to follow
    i. Press Ctrl + Alt + Delete buttons together and select Task manager
    ii. End all the process running in the background
    iii. And then try to sign in
    Method 2: Delete all the files under temp folder, steps to follow
    i. Click on start
    ii. Type in ‘%temp%’ in the search box
    iii. Delete all the files in this folder
    Method 3: Remove the Temporary internet files and folders, follow the steps listed in the below link:
    How to Delete the Contents of the Temporary Internet Files Folder:
    **http://support.microsoft.com/kb/260897**
    Please reply if you have any questions.
