Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2018-09-07T05:37:44+00:00
    kindly use command prompt run as administrator it may be fix your existing problem
    Regards
    Terminal IT Solutions
    KERALA
    2018-10-06T10:57:43+00:00
    Thanx, buddy it worked. I was going to to format my system.
    2018-10-07T10:07:15+00:00
    HRESULT 0xc8000222
    2018-10-07T10:46:20+00:00
    Run cmd as administrator,
    1. TYPE net stop WuAuServ ENTER
    2. TYPE ren C:\Windows\SoftwareDistribution softwaredistribution.lama ENTER
    3. TYPE net start WuAuServ ENTER
    4. FINISH
