Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2018-04-20T11:03:00+00:00
    Right click on cmd.exe and run it as administrator...
    It should solve the problem...
    This is very helpful. thankyou for your help.. really appreciate
    2018-04-25T18:16:20+00:00
    Consultez la fin de ce message pour plus de détails sur l'appel du débogage
    juste-à-temps (JIT) à la place de cette boîte de dialogue.
    ************** Texte de l'exception **************
    System.DllNotFoundException: Impossible de charger la DLL 'xul': Le module spécifié est introuvable. (Exception de HRESULT : 0x8007007E)
       à Gecko.Xpcom.NS_InitXPCOM2(nsIServiceManager& serviceManager, Object binDirectory, nsIDirectoryServiceProvider appFileLocationProvider)
       à Gecko.Xpcom.Initialize(String binDirectory)
       à Gecko.Xpcom.Initialize()
       à Gecko.GeckoWebBrowser.OnHandleCreated(EventArgs e)
       à System.Windows.Forms.Control.WmCreate(Message& m)
       à System.Windows.Forms.Control.WndProc(Message& m)
       à Gecko.GeckoWebBrowser.WndProc(Message& m)
       à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assemblys chargés **************
    mscorlib
        Version de l'assembly : 4.0.0.0
        Version Win32 : 4.7.2600.0 built by: NET471REL1LAST
        CodeBase : file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    _
        Version de l'assembly : 0.0.0.0
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
        Version Win32 : 4.7.2556.0 built by: NET471REL1
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    libs
        Version de l'assembly : 7.1.4.0
    System
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    37f3aa99-096e-4024-ae76-f02f6045646b
        Version de l'assembly : 1.0.0.0
    Bunifu_UI_v1.52
        Version de l'assembly : 1.3.0.0
        Version Win32 : 1.3.0.0
        CodeBase : file:///C:/Users/pc%20info/Desktop/EmbratoriaG7.1.4/Bunifu_UI_v1.52.DLL
    Geckofx-Winforms
        Version de l'assembly : 45.0.30.0
        Version Win32 : 45.0.30.0
        CodeBase : file:///C:/Users/pc%20info/Desktop/EmbratoriaG7.1.4/Geckofx-Winforms.DLL
    Geckofx-Core
        CodeBase : file:///C:/Users/pc%20info/Desktop/EmbratoriaG7.1.4/Geckofx-Core.DLL
    mscorlib.resources
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
        CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Débogage JIT **************
    Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
    application ou cet ordinateur (machine.config) doit avoir la valeur
    jitDebugging définie dans la section system.windows.forms.
    L'application doit également être compilée avec le débogage
    activé.
    Par exemple :
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
    seront envoyées au débogueur JIT inscrit sur l'ordinateur
    plutôt que d'être gérées par cette boîte de dialogue.
    2018-05-05T12:03:32+00:00
    Thank's lot dear,
          now i can install netframe work.
    Regard's
    Malik Basha
    2018-05-09T09:23:31+00:00
    thanks
    help me
