Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2013-09-04T05:23:03+00:00
    net stop WuAuServ
    net start WuAuServ
    Jessen,
    What might have caused problem to the Windows Update folder (%windir%\SoftwareDistribution) that required renaming the folder?  Is there anything needed to save and or merge to the newly created Windows Update folder?  Does it affect Windows updates such as removing or reinstalling?
    Thank you!
    2013-09-11T20:44:20+00:00
    thnx guys that was helpful :D
  3. Deleted
    2013-09-12T05:03:59+00:00
    The problem would have caused due to some corruption with the Windows Update folder. No, nothing need to be saved and merged to the newly created Windows Update folder. No, it does not affect Windows updates such as removing or reinstalling.
    @ Sherif,
    Glad to know that the issue is fixed. Let us know if you face any issues with Windows in future.
