Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2016-08-23T07:12:26+00:00
    Run "cmd" as administrator to avoid access denied problem.
    then
    **b:**Type cmdand press Enter.
    net stop WuAuServ
    c: Click Start > RunType %windir% and press Enter.
    e: Click Start> Runtype cmd and press Enter.
    net start WuAuServ
    It works for me.
    thanks.
    2016-08-23T23:14:37+00:00
    I followed this video on youtube and can resolve this error. Follow the link:  https://youtu.be/yK5oiKHkoYo
    2016-08-29T08:32:18+00:00
    This solves most off my issues relating to that error including installation of Dot net 4.0
    Thanks guys
    2016-09-18T11:39:32+00:00
    This sollution help me to install dotnet frame work without any error (stand alone instalation) .
