Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2016-07-18T06:42:49+00:00
    I need Help..I can not Rename the folder SoftwareDistribution To other name Folder (ex: SDold). " The action can't be completed because the folder or a file in it is open in another program".
    I Don't Open Any folder. Thanks
    2016-07-19T09:05:59+00:00
    1. go to Start -Run
    2. type %temp% hit Enter; delete all files from the folder.
    3. log off machine
    4.login to user account
    a: Click Start
    **b:**Type cmd right click and run as administrator
    net stop WuAuServ
    c: Click Start > RunType %windir% and press Enter.
    e: Click Start> Runtype cmd and press Enter.
    net start WuAuServ
    after install dotnet setup
    2016-07-26T04:28:20+00:00
    the prompt said the windows update is not started what should i do
    can't download framework
    2016-07-26T05:39:58+00:00
    a: Click Start
    net start WuAuServ
