Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2016-04-19T04:03:22+00:00
    Thank you
    It's work
    2016-05-01T13:11:39+00:00
    cmd command is not recognised and i am not able to rename that folder any other way to do it.
    2016-06-24T14:53:04+00:00
    I was unable to access directly, so I run as administrator but I am unable to rename the folder.
    2016-06-25T07:32:19+00:00
    1: Click Start >All Programs > Accessories >Command Promptright click and Run as administrator
    net stop WuAuServ
    2: Click Start > RunType %windir% and press Enter.
    3: In the opened folder, rename the folder SoftwareDistributionto SDold.
    4:  Click Start >All Programs > Accessories >Command Promptright click and Run as administrator
    net start WuAuServ
